1 - 7 of 7 Posts
Hello all
I'm new here and I looking forhelp because on myTouareg it was gearbox oil changed andI think is owerfiled.
DoI have to change the oil again or just drain it out that extra oil ?
2016 Touareg Lux TDI, 2019 Passsat R-line
You definitely need to drain off the extra if it's overfilled. Why do you think it's overfilled?
What procedure was used to fill the gearbox? Are you sure the correct fluid was used? We'd need to know that to know if you need to drain completely and refill.
On a manual, it would probably get a little frothy, maybe get some gears hot (binding shifts), spill out the breather hole(s).
On an automatic you're looking at an electronic tranny calling in sick or going to limp home mode, but otherwise you're looking at hard shifting, overheating, blown seals- basically, dollar signs.
Just out of curiosity, what damage will over filling cause?
That ^^
Not good at all.
1 - 7 of 7 Posts
