1 - 10 of 10 Posts
Fuse is #5 on driver's fuse panel
If you are able to log into the heater with VCDS and there's a code, and you press clear and it doens't, heater is locked out.
to unlock you need to go to adaptation and save a 1 in the first channel, i beleive it will be indicated that it resets the heater.
Then go back to fault screen and clear your error. Heater should fire back up unless something is actually prevending it from doing what it has to.
FYI just in case you are not aware, the Webasto will not start if the fuel tank is less than 1/4 full.
Or that ECON is on, or that fuel door is open, or that coolant temp G241 is more than 75C, or that outside temp G17 is more than 5C
Discussion Starter · #6 ·
Thanks for the advice,
I went to the dealer and at first the webasto was locked, they unlocked it and then they found that the glow plug and burner need to be replaced.
Does the touareg know when the fuel door is open? I thought that was just a phaeton thing.
On our 04 the heater runs with econ enabled. I think it will also run the heater until the low fuel light comes on.
-J
It might be something on the newer trucks perhaps. Our 04 does not shut off the parking heater when the fuel door is opened, or the truck is being refueled.
-J
1 - 10 of 10 Posts
