Hello friends,
we have the following situation ...with our Touareg V6 TDi 224 hp ~230 000 Km
We parked the car working in the evening everything fine no issues.
The morning was not so good ...
the car cranks but it refuses to start....
the car stays at a basement where the degrees does not fall under 0 Celsius Never
the fuel is Shell V-power the the tank is full.
So we suspect the battery --> bought brand new 820 Start 100 AH capacity and replaced the old one.
The problem remains .... car cranks but won`t start at all .
No errors on dashboard
I connected the Vcds to check out what is the problem.
The only problem is that High pressure bars are 0.0 and don`t change when it cranks ...
We sucpect the High pressure pump because when we test those in tanks we can hear them and fuel is delivered to the fuel filter....
I will attach the full scan log and live data from engine while cranking.
Can the suspected pump be dead after one night without even working ....
Greets thanks for your time.
here is the live data:
Saturday,15,January,2022,17:45:57:14499-VCID:2AE3E69D30B514640A-5179,VCDS Version: Release 20.4.0,Data version: 20200411 DS317.0
7L0 907 401 B,,3.0L V6TDI A000AG 0090,
,Group A:,'001,,,,Group B:,'003,,,,Group C:,'004
,,Engine Speed,Injection Quantity,High Fuel Pressure,Coolant,,Engine Speed,Exhaust Gas,Exhaust Gas,Exhaust Gas,,Engine Speed,Injection Start,Injection Duration,High Fuel Pressure
,TIME,(G28),,(actual),Temperature (G62),TIME,(G28),Recirculat. (spec.),Recirculat. (actual),Recirc. Duty Cycle,TIME,(G28),(specified),(specified),(actual)
Marker,STAMP, /min, mg/str, bar,°C,STAMP, /min, mg/str, mg/str, %,STAMP, /min,°KW, ms, bar
,0.47,0,0.0,0.0,5.4,0.12,0,1198.5,0.0,92.6,0.29,0,3.4,0.00,0.0
,0.99,0,0.0,0.0,5.4,0.65,0,1198.5,0.0,92.6,0.82,0,3.4,0.00,0.0
,9.62,147,36.5,0.0,5.4,8.23,0,0.0,0.0,5.4,9.46,147,3.4,0.00,0.0
,10.13,147,36.5,0.0,5.4,9.79,126,1198.5,528.8,94.6,9.96,126,3.4,0.00,0.0
,10.65,126,36.5,0.0,5.4,10.31,147,1198.5,534.6,94.6,10.48,147,3.4,0.00,0.0
,11.16,147,36.5,0.0,5.4,10.82,147,1198.5,534.6,94.6,11.00,147,3.4,0.00,0.0
,11.68,147,36.5,0.0,5.4,11.34,147,1198.5,452.4,94.6,11.51,126,3.4,0.00,0.0
,12.20,126,37.6,0.0,5.4,11.86,147,1198.5,505.3,94.6,12.03,147,3.4,0.00,0.0
,12.73,147,39.3,0.0,5.4,12.38,147,1198.5,522.9,94.6,12.55,147,3.4,0.00,0.0
,13.24,147,40.9,0.0,5.4,12.90,147,1198.5,534.6,94.6,13.07,126,3.4,0.00,0.0
,13.76,126,42.8,0.0,5.4,13.41,147,1198.5,528.8,94.6,13.59,147,3.4,0.00,0.0
,14.27,147,44.5,0.0,5.4,13.92,147,1198.5,534.6,94.6,14.10,147,3.4,0.00,0.0
,14.78,147,46.1,0.0,5.4,14.44,147,1198.5,517.0,94.6,14.61,126,3.4,0.00,0.0
,15.31,147,48.0,0.0,5.4,14.96,147,1198.5,475.9,94.6,15.14,147,3.4,0.00,0.0
,15.82,147,49.7,0.0,5.4,15.48,126,1198.5,517.0,94.6,15.65,147,3.4,0.00,0.0
,16.34,126,51.3,0.0,5.4,16.00,147,1198.5,517.0,94.6,16.17,147,3.4,0.00,0.0
