1 - 20 of 107 Posts
Revised as of Jan 04, 2013
These rates for Touaregs!
Just a note. These rates for 2011 and 2012, and 2013 Touaregs!
Chris here from VW of Langhorne in Langhorne, PA.
The VW Drive Easy extended service contracts have changed as of Jan 01,2008
They have now combined the new car extension w/ the used car extension and
have come up w/ one main plan.
Now the time starts the day you sign up and the miles you choose are on top
of what you allready have!
They still have the same verbage in the new contract as far as coverages
that will be explained here:
> Allthough I am open to all coverages, I would reccomend the Platinum
> coverage as it is an exclusionary warranty vs an inclusiuonary warranty!
> These quotes are w/ a std $100 deductible.
> Should you want a $0 deductible, please add an additional $230-$517
> depending on the terms you choose!
The $100 std deductible is per visit, NOT per complaint!
> This extended service contract is valid at ANY VW dealer and the dealer
> gets
> paid thru their parts and warranty dept.
> This warranty is also valid at authorized shops and they get paid thru a
> credit card.
> You are never responsible for more then your deductible!
> If you cancel in the first 60 days, it is 100% refundable, after the 60
> days, it costs $50 and the plan will be pro-rated!
> To transfer the contract it costs $40!
> The warranties I sell are geuine VW warranties. I DO NOT deal in
> aftermarket
> warranty companies! The service contract is backed by VW and fascilitated
> thru Fidelity Warranty Services!
> Here are the coverages:
> The Gold covers:
> Engine
> Transmission
> Drive axel
> Steering
> Brakes
> A/C
> Front Suspension
> Electrical
> The Gold Plus covers all of Gold plus:
> Cooling System
> Fuel System
> A/C system
> Steering
> Front Suspension
> Rear suspension
> Electrical
> The Platinum covers all that and the rest of the entire car w/ the
> exception
> of this:
> brake linings,brake drums and rotors,disc brake pads,std trans clutch
> components,air bags,solar powered devices,hinges, glass, lenses,sealed
> beams,trim moldings,door handles, lock cylinders,tires, batteries, light
> bulbs,upholstery, paint,bright metal,freeze plugs,heater and radiator
> hoses,exhaust systems,shock absorbers,audio,security or other systems not
> factory installed, work such as front end alignment or wheel balancing,
> constant velocity joint boots, safety restraint systems,cellular
> phones,electronis transmitting devices{except those specifically listed
> under silver, gold, or gold plus coverage},radar detectors,appliances,near
> object avoidance systemand all oither laser radar cruise control
> components,
> vinyl and convertible tops.
Here are the quotes depending on how many miles are on your Touareg
Please note that this contract starts from the day you sign up and the
miles
are on top of what you allready havexxxx +
These quotes are vaild until you hit 9999 miles or the end of the year!
4yrs or 100K=$1266 + 6% pa tax
5yrs or 60K=$941 + 6% pa tax
5yrs or 75K=$1035 + 6% pa tax
5yrs or 100K=$1335 + 6% pa tax
6yrs or 60K=$941 + 6% pa tax
6yrs or 72K=$1099 + 6% pa tax
6yrs or 85K=$1176 + 6% pa tax
6yrs or 100K=$1564 + 6% pa tax
7yrs or 70K=$1158 + 6% pa tax
7yrs or 100K=$1706+ 6% PA TAX
10yrs or 10K=$2232 + 6% pa tax
These quotes are valid up to 24999 miles{note, you get an additional 15K, however, the price jumps dramatically!}
4yrs or 100K=$2028 + 6% pa tax
5yrs or 60K=$1597 + 6% pa tax
5yrs or 75K=$1988 + 6% pa tax
5yrs or 100K=$2327 + 6% pa tax
6yrs or 60K=$1693 + 6% pa tax
6yrs or 72K=$1919 + 6% pa tax
6yrs or 85K=$2392 + 6% pa tax
6yrs or 100K=$3128 + 6% pa tax
7yrs or 100K=$3421 + 6% pa tax
These quotes valid up to 34999 miles
3yrs or 36K=$1387 + 6% pa tax
4yrs or 48K=$1712 + 6% pa tax
4yrs or 60K=$1988+ 6% pa tax
5yrs or 60K=$2065 + 6% pa tax
5yrs or 75K=$2535 + 6% pa tax
6yrs or 60K=$2124 + 6% pa tax
6yrs or 72K=$2425 + 6% pa tax
These quotes valid up to 44999 miles
3yrs or 36K=$1787 +6% pa tax
4yrs or 48K=$2177 + 6% pa tax
4yrs or 60K=$2396 + 6% pa tax
5yrs or 60K=$2466 + 6% pa tax
6yrs or 60K=$2594 + 6% pa tax
6yrs or 72K=$3407 + 6% pa tax
__________________
Chris, are there any extended warranty options available for 2006 Touaregs or is it to old? I only have 42k on it.
Thanks,
Kurt
I cant tell if you are quoting Gold or Platinum plans.
Would you ballpark an estimate of the spread between Gold and Platinum
Official CT Ricer!
Thanks,
Kurt
I believe you need to be under warranty at the time of extension. Tou could be under the factory warranty (which I believe is expired in your case) or an existing VW extended/Pre-owned warranty. Unless you are covered right now by one of the above, you cannot be extended from what I can remember.
I just had the balance of the 3yr/30k warranty on it when I bought it in early 09. I don't remember getting any offers for extended warranty at that time, though I have received recall notices from VW - such as the coil replacement. I wasn't sure if I even qualified for one anymore..... thanks for your reply
Discussion Starter #9
Thanks,
Kurt
I canput the VW Drive Easy contract on your Touareg, however, you wouild have to go to your local VW dealer and get me a clen bill of health on it so that everything is up to par!
Here are the quotes
> gets
> credit card.
> aftermarket
> The Gold covers:
> Engine
> Transmission
> Drive axel
> Steering
> Brakes
> A/C
> Front Suspension
> Electrical
> Cooling System
> Fuel System
> A/C system
> Steering
> Front Suspension
> Rear suspension
> Electrical
> exception
> of this:
> components,
miles
are on top of what you allready have 42xxx +
$100 deductible
3yrs or 36K=$1925 + 6% pa tax
4yrs or 48K=$2320 + 6% pa tax
4yrs or 60k=$2561 + 6% pa tax
5yrs or 60K=$2632 + 6% pa tax
6yrs or 60K=$2713 + 6% pa tax
6yrs or 72K=$3213 + 6% pa tax
$250 deductble {per visit, NOT per problem}
3yrs or 36K=$1628 + 6% pa tax
4yrs or 48K=$1900 + 65 pa tax
4yrs or 60K=$2068 + 66% pa tax
5yrs or 60K=$2018 + 6% pa tax
6yrs or 60K=$2174 + 6%$ pa tax
6yurs or 72K=$2518 + 6% pa atax
Discussion Starter #11
I always quote Platinum plans and that is what I recommend.
The differance between the Platinum and Gold Plus is approx $280 and $560 down the Gold plans
Hi,
Are any of the items not covered in the Platinum plan a big deal.I am a numnut when it comes to car mechanics,and this is my first non Japanese car.
I ask this as my VW dealer quoted me an all inclusive warranty,that was substantially more than your quotes..as in double
Thanks again,
Allan
Here are the quotes
> gets
> credit card.
> aftermarket
> The Gold covers:
> Engine
> Transmission
> Drive axel
> Steering
> Brakes
> A/C
> Front Suspension
> Electrical
> Cooling System
> Fuel System
> A/C system
> Steering
> Front Suspension
> Rear suspension
> Electrical
> exception
> of this:
> components,
miles
$100 deductible
Quote for 2006 Treg
I am in a similar situation as this guy with 42xxx, I am buying a 2006 w 48000. What would be the rates for this TReg? There would be no problem getting a Checkout by VW.
T.C.
> gets
> credit card.
> aftermarket
> The Gold covers:
> Engine
> Transmission
> Drive axel
> Steering
> Brakes
> A/C
> Front Suspension
> Electrical
> Cooling System
> Fuel System
> A/C system
> Steering
> Front Suspension
> Rear suspension
> Electrical
> exception
> of this:
> components,
miles
$100 deductible
6yurs or 72K=$2518 + 6% pa atax[/QUOTE]
Discussion Starter #14
Hi,
Thanks again,
Allan
Allan,
If you are asking me my personal feelings on are any of the exclusions items big deals. Sure, some of them are, however, they are wear and tear items that you just cant hold anyone or any manufacturer responsible for.
On the other note, I am glad to hear that my quotes are 1/2 of your dealers quotes.
This is what the club is designed for my friend!
Chris
VW Easy drive
Chris,
We actually spoke 3-4 weeks back and I am still finalizing the purchase of the vehicle, but
I do not have the figures you sent . Could you give me an update on what it would cost for a Platinum plan for a 2006 Treg w/48xxx?
Thanks for the time!
Tom
Discussion Starter #18
Chris,
Tom
Platinim Plan
Std $100 deductible
2yrs or 24K=$1908 + 6% pa tax
3yrs or 36K=$2350 + 6% pa tax
4yrs or 48K=$2998 + 6% pa tax
4yrs or 60K=$3407 + 65 pa tax
5yrs or 60K=$3465 + 6% pa tax
Chris,
I am looking at 2009 Touareg TDI.
AutoCheck looks clean; shows ~72,400 miles and one owner.
What would be the cost of the Platinum plan and what do I have to do to qualify?
Thanks for the quick reply Chris, I will be in touch to get the specifics about securing this.
I know I have to get VW to inspect the vehicle but I need to know a few more things.
Tom
1 - 20 of 107 Posts
About this Discussion
36 Participants
noobytoogy
Club Touareg Forum
Full Forum Listing
