1 - 3 of 3 Posts
I’m getting a vibration at high speed. It can vary on the day. Sometimes it’s at 100 kph and other times it starts at 120 kph. It’s not the input shaft (driveshaft) bearing. It’s been done already. It seems more from the rear end but it’s hard to tell.. it really vibrates the crap outta the whole car. Help please!?
Get your wheels\tires checked for proper balancing. You probably dropped a wheel weight and\or have a broken belt or a tire bulge starting to develop. It could also be a bent rim if you've hit some nasty pothole, etc. A decent tire shop should be able to tell you once they attempt to re-balance your gear.
1 - 3 of 3 Posts
