2004 Touareg V10 TDI
Recently my car has been having an issue starting and showing a low voltage. In VCDS I checked the battery voltages and the accessory battery shows 10.8v (dead) and the starter battery show N/A. I manually checked the started battery and it has a voltage of 12.7. I assumed that when you when to start the car it would switch over to the starter battery and use that to start the car. I can hear the solenoid click on in the back when trying to start the car but only get a slight chug and then nothing. I did check the isolation switch under the drivers seat and it is showing the copper coil in the sight glass. I don't know if this is just a 2004 thing that it doesn't show the voltage for the rear battery or what, I have search and searched but couldn't find anything on VCDS not showing voltage for the starter battery.
Also does the battery need to be re-coded if replaced, I have seen mixed opinions on this and VCDS times out when trying to get into the sections that are in the given instructions that I have seen.
One other thing if put on a charger the car will start and run just fine through out the rest of the day and then over night go dead. I assume that there may be a bad cell in the battery, it is 8 years old and hasn't had any issue prior to this.
Thank you,
Thank you,
