1 - 18 of 18 Posts
New to all this stuff and looking for some sage advice. This is just all gobblygook to this novice!
Just completed a VCDS (Ross Tech) scan of my 2015 7P TDI Touareg. Four FAULTS detected:
03 ABS brakes status: Malfunction 0010
771080 Databus U1122 00 [008] Implausible message
[Signal Parkbremse unuplausible] Intermittent - Confirmed - Tested since memory clear
Freeze Frame: Fault Status 00000001 Fault Priority: 2 Fault Frequency: 1
Reset counter: 47 Mileage 94441km
Standard Freeze Frame Dynamic: 00 3C 00 00 04 00 00 10 00 00 03 1
09 Cent. Elect. -- Status Malfunction 0010\
1 Fault Found:
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Freeze Frame:
Fault status: 01 101100 Fault Priority: 2 Fault Frequency: 1 Reset Counter: 243 Mileage 92572
Time indication: 0
19 Can Gateway -- Status: Malfunction 0010
2 Faults Found:
12290 - Quiescent Current
U1406 00 [009] - Too High Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault status: 00000001 Fault Priority: 7 Fault Frequency: 3 Reset Counter: 196
Mileage 89224km
Voltage terminal 30: 12.7 V Voltage terminal 15: 0.0 V Control Module temperature: 32 C
System Status: LIN active IN ESP_standstill flag: no standstill detected Engine running: OFF
IN ZAS_Te_X: OFF Terminal 15 status via CAN: OFF Terminal 15 status: OFF Datenfiled: 0
16384 - Function Restriction due to Driver Fatigue Recognition
B130E 00 [008] [Funktionseinschraenkung Pausenempfehlung]
Freeze Frame:
Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 222
Reset Counter: 71 Mileage: 83989 km
Voltage terminal 30: 14.3V Voltage terminal 15: 14.4V
Control Module temperature: 34 C System status: Terminal 15 on
IN ESP_ standstill flag: no standstill detected IN ZAS_Te_X: On
Terminal 15 status via CAN: On Datenfeld: 0
1 Fault Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 011000000 Fault Priority: 6 Fault Frequency: 1
Reset Counter 124 Mileage: 83961 km Time Indication: 0
Freeze Frame:
Txt : DUA001, Front 0 , 6 , 0 ,
Are these of any concern and any ideas on rectification of each Fault Code, please?
My 2012 Touareg just kicked out the the 12990 error code at dealership last week when they were trying to program a new key fob for me. They scheduled me for another appointment to do diagnostics. Am trying to do some research to better understand the problem.
2015 R Line V8
Victor, if this is your first scan of the car. May I suggest you clear ALL codes before doing anything else, then take it for a drive. When you get back home (make sure you can get to highway posted speed limits, in case there are some speed dependant errors in there), do another scan. The 2nd scan is the one we'll be interested in and can possibly guide you with.
Discussion Starter · #4 ·
Hi Steve,
Thank you Mate. I sincerely appreciate your advice. I will clear all the codes tomorrow and take the car for a run following your advice and then run another scan. I note that do have and intermittent issue with the brake that holds the car on hills where it appears to decide when it will work as intended and both the LED's in the RH head lamp (DRL & Park) are not working.
Will post my new scan tomorrow after a good run.
Thank you gain for your advice.
Kind Regards,
Vic B
Burrum Heads Qld
Discussion Starter · #5 · (Edited by Moderator)
Hi Steve,
Cleared all faults as you suggested and too the beast for highway run 100-120k and hour and then back home for another scan and you were 100% on the money. Most of the faults vanished.
Here is my scan today with faults showing up in 09 Cent Elect Malfunction; 5F Information Electr: Malfunction :
Tuesday,23,November,2021,14:00:02:05126
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WVGZZZ7PZFD004087 License Plate: 900VTW
Mileage: 96145km-59741mi Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 34 36 42 46 52 53 55 56
5F 62 6C 6D 72
VIN: WVGZZZ7PZFD004087 Mileage: 96145km-59741miles
01-Engine -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
34-Level Control -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
Address 01: Engine (J623-CRCA) Labels:. 059-907-401-V2.clb
Part No SW: 7P1 907 401 A HW: 4G0 907 401
Component: 3.0TDI EDC17 X41 0001
Revision: 53X41--- CVN: BB270E97
Coding: 292A4012232E01020000
Shop #: WSC 29226 002 1048576
ASAM Dataset: EV_ECM30TDI0117P1907401A 001002
ROD: EV_ECM30TDI0117P1907401A.rod
VCID: 2E050936E096051B05D-807A
VINID: 9E65EAAAA1E0A965000040081C72257611
No fault code found.
Readiness: 0 0 0 0 X
Address 02: Auto Trans (J217) Labels: 0C8-927-755.clb
Part No SW: 0C8 927 755 M HW: 0C8 927 755
Component: AL1000 AISIN 100 2816
CVN: 4EFDC3E5
Coding: 010100011C008400000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_TCMAL991031 003118
ROD: EV_TCMAL991031_003.rod
VCID: 3B23306223E4E0B3B23-806E
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 R HW: 7P0 907 379 A
Component: MK25A H37 0521
Revision: -------- Serial number: 421940010EC010
Coding: 5B6B13C34B242557DAF4C89BD2D9A470F701
ASAM Dataset: EV_MK25AXT 010001
ROD: EV_ESPMK25A01000.rod
VCID: 4CC163BE764A570B0B9-8018
Part No SW: 4H0 907 064 FM HW: 4H0 907 064 EM
Component: BCM2 2.0 H36 0551
Revision: 00002001
Coding: 05B60016000000000000
VCID: 79AFEA6A69D812A3E0F-802C
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H40 0046
Serial number: 3214000104202014
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-BFS H08 0156
Revision: AA000000 Serial number: 00000117642337
Coding: 0038330000004201000001010101202020202121202020
VCID: 34311B5E0E3A2FCB739-8060
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 CD HW: 7P6 907 040 CD
Component: Klima 2 Zonen H23 1406
Coding: 3626200E90
VCID: 78A9EF6E52520BAB9F1-802C
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DA HW: 4H0 907 063 AA
Component: BCM1 2.0 H20 0311
Revision: 22020001 Serial number: 00000901639702
Coding: 26000014D0345D010029400780005D4C431D470827010241800000000040110000000000000000
VCID: 6A8DC5261C7EA93B195-803E
Subsystem 1 - Part No SW: 7P0 955 120 HW: 7P0 955 120
Component: WWS 140906 033 0021
Serial number: 90243401140924073958
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20407207
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 AB HW: 7P6 941 431 AB
Component: E1 - LDS H02 0040
Serial number: 00000000001010140056
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA109143000009295588
Coding: 020300
1 Fault Found:
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 33
Mileage: 96101 km
Time Indication: 0
Date: 2021.11.22
Time: 08:10:06
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 D HW: 7N0 919 475
Component: PARKHILFE 8K H06 0030
Revision: -------- Serial number: 28261428001376
Coding: 508504
ASAM Dataset: EV_VW526ParkiAssis2 001013
ROD: EV_VW526ParkiAssis2.rod
VCID: 44D14B9E5E1A9F4BC39-8010
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 E HW: 7P0 959 655 E
Component: VW10Airbag03F H10 0043
Revision: -------- Serial number: 003NK0014SPI
Coding: 000000000000000000000000000000003346
ASAM Dataset: EV_AirbaVW10BPAVW526 002001
ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
VCID: 43D348825B149873FA3-8016
Serial number: 3575LRB40512QP0SCPG8
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585LRB405L2P6B6AHP/
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3517ARB40692T8H8COS$
Passenger side rear thorax airbag crash sensor:
Serial number: 3527ARB40692T8H8DGSX
Serial number: 3557BRB40552T32G60DP
Serial number: 3567BRB40552T32GJH33
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 K HW: 7P6 953 507 AB
Component: Lenks.Modul H06 0005
Revision: -------- Serial number: 90862NJ20011A
Coding: 000015
VCID: 3B2330622364E0B3B23-806E
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H05 0028
Serial number: 0016741 TRW 20140905
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 883 B HW: 7P6 920 883 B
Component: Kombi H13 0515
Revision: 13240300 Serial number: 658250914592001
Coding: 333733003A00000800000C
ASAM Dataset: EV_KombiUDSRBVW526 001022
ROD: EV_KombiUDSRBVW526.rod
VCID: 3D273E7A3DF0EE838C7-8068
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 7P6 907 530 M HW: 7P6 907 530 F
Component: GW-CAN-L-MOST H13 6042
Revision: -------- Serial number: 00000001580269
Coding: 000D07AD00
GVL: FF4F40C51D67000000
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
VCID: 42DD4D86440E917BF15-8016
Subsystem 1 - Part No SW: 7P0 915 181 B HW: 7P0 915 181
Component: Batt_Sensor H07 0190
Serial number: 41266D34565701796611
Voltage stabilizer:
Subsystem 2 - Part No SW: 7PP 959 663 E HW: 7PP 959 663 E
Component: J532_DCDCStab H17 0042
Serial number: 14273003132011200181
Address 34: Level Control (J197) Labels:. 7P0-907-553.clb
Part No SW: 7P0 907 553 AF HW: 7P0 907 553 AF
Component: PASM H05 0750
Revision: 00000000 Serial number: 00000142790576
Coding: 14210000
ASAM Dataset: EV_PASMConti 001005
ROD: EV_PASMConti.rod
VCID: 7BA3F062636420B3F23-802E
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000117692163
Coding: 00383B0000004201000001010101202020202121202020
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H02 0306
Revision: -------- Serial number: 0000119669892
Coding: 011D1620DE01451205080002
VCID: 7AADF5666CDE19BBE95-802E
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0348163033
Coding: 011B1E2028B9108183200624010000000000000000000000000000000000
Subsystem 1 - Part No: 7P6 951 171
Component: DWA-Sensor 002 0204
Subsystem 2 - Part No: 1K0 951 605 C
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000120438528
Coding: 011D1620DE01451205080000
VCID: 48C95FAE62B2BB2B2F1-801C
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C14A1200612
Coding: 01040100
ROD: EV_ParkbA7.rod
VCID: 3635215618C63DDB4DD-8062
Slave 3:
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Revision: -------- Serial number: --------------
Coding: 01A602000B000200
ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
ROD: EV_HeadlRegulAFSMQBMLB.rod
VCID: 3FDB447237FCFC939EB-806A
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0005
Coding: B00000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0005
Coding: B00000
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G1 035 053 J HW: 4G1 035 053
Component: Radio U Basic H41 0133
Revision: AB001007 Serial number: 227J40E8486181
Coding: 040005020100000003
VCID: 2615F116C8E64D5BFDD-8072
Part No SW: 7P6 035 764 E HW: 7P6 035 764 A
Component: H-BNT-RW H40 0816
Revision: -------- Serial number: 445IW0E7502330
Coding: 010A01050040C1EF41000B0E00000003F00001030000000000
Subsystem 1 - Part No: 8R0 060 884 GC
Component: ROW 2019 1104
Subsystem 2 - Part No SW: 7P6 919 603 J HW: 7P6 919 603 J
Component: DU8 SV Touch H52 0046
Serial number: VWZ8Z9PX7003PH
Subsystem 3 - Part No SW: 7P6 919 603 J HW: 7P6 919 603 J
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5571
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 33
Mileage: 96101 km
Time Indication: 0
Date: 2021.11.22
Time: 08:10:34
Freeze Frame:
Text: DUA001,Front,M,0,0,6
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H03 0306
Revision: -------- Serial number: 0000120936033
Coding: 011814200001251005080000
Address 6C: Back-up Cam. (J928) Labels:| 7P6-907-441-V1.clb
Part No SW: 7P6 907 441 G HW: 7P6 907 441 G
Component: TopView H08 0115
Revision: 11001001 Serial number: 82330JF0181387
Coding: 0100000001000000000102000000
ASAM Dataset: EV_CamerSysteTopViewVW 001014
ROD: EV_CamerSysteTopViewVW.rod
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 261400967
Coding: 0533314002
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0306
Revision: -------- Serial number: 0000120955111
End----------(Elapsed Time: 02:02, VBatt start/end: 12.2V/12.4V)-----------
How to proceed from here?
Thank you for your interest and assistance. From a VCDS novice, you are greatly appreciated.
Kind Regards,
Vic
2015 R Line V8
Excellent Vic, what I will do is trim your post and remove info pertaining to modules that do not show a fault (just housekeeping mate).
While driving, are all electronic functions working, especially in respect to the infotainment system?
I'm going to check against my scans and see if I can see a difference.
In the meantime, despite the error code....if all is ok, then don't fiddle ;)
2011 VR6 FSI LUX
Doesn't the 5F module store that same fault when the firmware for the MMI is updated without being connected to VW's mothership?
I have it on mine after doing so.
2015 R Line V8
Checked mine....does not have that particular fault for 5F.
Discussion Starter · #9 ·
Interestingly, this seems to have popped up since having my maps updated at the VW dealership. Maybe there is something associated with the RNS850 system when maps are updated?
2011 VR6 FSI LUX
Did you update the firmware yourself? Also did you change any #'s in adaption, channel 15 using a code calculator and test and save it?
2011 VR6 FSI LUX
I searched a bit and found a video on YouTube. The poster was kind enough to leave a URL to his webpage which has full instructions on how to use his calculator and how to enter and save a new value using VCDS to get rid of it.
I haven't tried it on mine yet so I don't know if it's a permanent fix or temporary.
The important take I got from his page is that your code is, according to him, from updating the firmware presumably without having it done at a dealership or maybe at one where it wasn't connected to VW's mothership.
Link >>>
Reactions: Steve_L
2011 VR6 FSI LUX
Reactions: Steve_L
2015 R Line V8
I was asking Steve_L!
I believe I did a minor update myself of the firmware when I first got the car. It's never had a map update tho.
VCDS scan shows no software errors in module 5f on my car.
2011 VR6 FSI LUX
My suggestion, instead of trimming it, would be to put it in the way the thread I saved below shows. Then the Scan is in it's own scrollable section that is small but retains all the info. When you edited it I can not see the 09- Central Elect. malfunction code.
Link >>>
Mod note - Full VCDS scan re-instated :cool: *
Reactions: Steve_L
2011 VR6 FSI LUX
I also did a firmware update myself but not the NAV.
I have a 03175 - Invalid Data Set fault that I have so far not been able to get rid of.
I have been told it's not possible without VW's mothership. I continue to search for a script online to resolve it.
Reactions: Steve_L
Discussion Starter · #18 ·
Link >>>
Big thumbs up to Steve & carsie.net for excellent VCDS solution. Followed instructions to the T . Issue gone!
Link >>>
1 - 18 of 18 Posts
