1 - 7 of 7 Posts
Hello!
I found some interesting VCDS coding in a russian forum thread the one mostly interesting is to imrove Dynaudio sound quality with RNS850. I guess it's some kind of self adaptation?
Anyone tried this? It's not crystal clear what it really means when using google translate from Russian.
Also found coding what i think is the car giving a noise when turning the alarm on.
????????? Bluetooth, Webasto, ????? ? ???????? ? ?????? ???? VCDS ??? NF - ????? - ?????? ???? ??????
I managed to translate this from a russian forum:
Turn on the sound profile Dynaudio amplifier (which is characteristic improves the quality of the musical path)
1. Select the block "56 - Radio"
2. Go to the "07 - Encoding" and then click "long coding"
3. Byte 4 - Replace the value 01 to the value 00
4. Close the dialog box, click Run, and then hand over the car under guard for about 15 minutes.
After this time, open the car and be surprised by how the sound has been changed before. Usually there is a surplus of low frequencies by volume, (but they are getting better over a range of frequencies).
On standard acoustic equalizer to set the value of the smaller, and while the tops can be raised. Such are the dynamics in stock ..
Sound proof removal / arming (when the immobilizer option available)
Audio confirmation of arming.
1. Select the block " 46 - Central module convenience system"
2. Go to " 07 - Encoding " and click on " Long coding "
3. Byte 1 - Bit 2 - Set marker
4. Close the window, click Run
confirmed only arming. It only works on machines with serial alarm (if there is a button in front of the luggage compartment on the driver's door) Audio confirmation of disarming. 1. Select the block " 46 - Central module convenience system" 2. Go to " 10 - Adaption " 3. Select channel 63 . 4. Set 188 . 5. Click " Test " 6. Click " Save " 7. Click " Done ", " Back " is confirmed only disarming. It only works on machines with serial alarm (if there is a button in front of the luggage compartment on the driver's door)
I bet someone used google translator too (to write that text in Russian).
Commenters wrote it's worth to try.
Interesting, I wounder what you do with the coding? Enter some kind of adaptation mode?
If I understand it correctly you should leave the car for 15mins?
I have neither NF Treg nor diagnostic tools. I just read original text in Russian and found it a bit weird as would someone used google translator too.
According to the instructions you have to "close the window" ?!(probably the software interface window), press "Run" and keep the car under security system for approx. 15 min. Then open the car ...
Feels a bit strange...
But it looks like some of the guys in that thread have tried this and had great outcome?
1 - 7 of 7 Posts
