Hi I have a 2012 touareg. i recently put a OEM wiring kit on and had the dealer run the VAG on it to tell the car that it was there. when i plug a trailer into it i get blinkers, running lights, but NO brake lights? here is a copy of the VAG report that he gave me. can someone tell me if there is something wrong on this side of things? i have plugged about 5 different trailers and the results are the same, NO brake lights. i am running a 7pin to 4 pin converter if that makes any difference.
thank you
thank you
