1 - 8 of 8 Posts
Hi all,
I found out that the vacuum pipe (7l6611932d) on my 2004 V10 cracked and prevented my brake booster from getting a proper vacuum.
I read some guys replaced their pipe with a silicone vacuum hose. It seems the installation thereof would be easier - the removal of the original did not go easily, cannot imagine what reinstalling one would mean...
My question: what kind of silicone hoses did you install? Interior diameter 9mm and external 12mm? Most importnatly: are you not worried the inherently softer silicone hoses will get "crushed" by the vacuum?
Best,
When your vacuum lines go bad def replace them with silicone vacuum tubing. Use someone like this: Verocious Platinum Cured Silicone Vacuum Hose - Sold by the Foot
I'm not sure of your exact diameter but I'm sure you could easily find out or ask the dealer
Silicone will not crush under most vacuum usages BUT you cannot use silicone for your primary vacuum line for your brake booster
When you mean I should not use silicone for my primary vacuum line you mean the entire length that runs from the tandem pump (V10) to the brake booster?
Yes that huge thick vacuum line MUST be reinforced rubber brake specific line
Reactions: VD-CH
I honestly don't have the know how to deal with that. I think I'll buy the OEM piece and try to fit it again. Thanks for clarifying, you saved me from making a big mistake!
My man. Always swooping in for the kill.
1 - 8 of 8 Posts
