1 - 3 of 3 Posts
I keep getting a lean bank 2 engine code set on my 06, 4.2. Can't find a vaccuum leak. Has anyone come across this before?
Also have an engine rattle at start and acceleration. I understand this is valve system chain tensioners. Is there a site showing this repair?
hi. first of all you need to scan your touareg using VAG COM VCDS and see what fault codes it shows. copy and paste them here,
it will help other to guide you to solutions
OK, Posted this in another section earlier so here goes again.
My 06 4.2 keeps setting an engine code. Today I noticed it seems to be on moderate braking. I have checked as many vacuum connections I could get to and re set the code. No codes set for several days and today it set again.
The codes are; P0174 MOD$10
Bank 2 system too lean.
Anyone seen this before? Thanks for any help!
1 - 3 of 3 Posts
