My V8 FSI has a JHM lightweight crank pulley, custom exhaust with secondary cat bypass pipes and a custom Malone tune.Has anyone done any engine mods to there Tregs?
What's different from your custom Malone tune and what they off as their Stage 1 kit??My V8 FSI has a JHM lightweight crank pulley, custom exhaust with secondary cat bypass pipes and a custom Malone tune.
I have had Malone tunes on several cars including TDI and FSI motors. He started with a generic stage one then requested VCDS logs in order to see if there was any room for improvement. Ive had two updates and each update was better than the generic stage one tune. With the Flashzilla tool, I can download the tune or return to stock in my garage. I plan on taking it to an AWD Dyno soon to see what it puts down.What's different from your custom Malone tune and what they off as their Stage 1 kit??
what does the lightweight crank pulley do and can it fit on a 04 v8 Touareg?My V8 FSI has a JHM lightweight crank pulley, custom exhaust with secondary cat bypass pipes and a custom Malone tune. .
Reduces rotating mass by 5 lbs. which frees up more HP. I found it revs quicker especially at lower RPM.what does the lightweight crank pulley do and can it fit on a 04 v8 Touareg?
