1 - 3 of 3 Posts
After 3 weeks with a new V8, I'm starting to get a better idea of the performance of the car. One thing I notice is the engine is relatively flat from about 2,000-2,700rpm. Once it hits 3,000rpm the engine seems to wake up with a completely different tone, altogether much more urgent and lively.
I am not sure whether this is the characteristics of this engine or a specific problem with mine. Just want to hear from other people about their experience with the engine. Thanks in advance.
Perhaps it's the Adaptive Transmission...
I noticed the same problem with my second V8. I reset the transmission and it was fine (it was adapting to my gentle break-in driving). To reset the transmission, turn off the car then turn the key so all the engine lights come-on (don't restart it). Push the peddle slowly all the way to the floor, hold it for second and release it. Repeat another 1-2 times.
This description of the Adaptive Transmission is straight from VWoA.
VW's Adaptive Transmission is an electronically controlled automatic transmission that continuously selects from a range of sift strategies to match the driver's needs and driving style. During sporty driving, the transmission holds the lower gears longer to keep the engine in its most powerful range. It also shifts down more quickly in response to gas pedal movement for maximum acceleration. When the transmission is driven for the best fuel economy, it shifts to the highest gears as soon as practical and maintains higher gears longer. The control unit gathers information from speed and load sensors, throttle pedal actuation and the engine control module. Because it continuously monitors these conditions, the transmission is able to respond to any change in driving style with an appropriate shift strategy.
There's nothing wrong with your car, the engine's powerband starts at about 3200 RPM. There's still ample power below that, however.
1 - 3 of 3 Posts
