While I have my engine out I am very tempted to get a front exhaust section made to delete the cats (2004, no DPF)
{For off-road use only of course}
Because I like to have bases covered and options available, and for Justin Case, I want to make them to have the same 3-bolt flange in front of the second cat or DPF, so if it were to require a visual inspection (at sale time or similar) the secondary cat could be re-fitted and most likely pass a visual with flying colours. It's not like the primary cat is exactly easy to see anyway.
I've 3D printed some snap fit exhaust pipe dummies to set it out for clearances etc. I've put angle marks all over the elbows so I can record the set-out and recreate the pipes in 3D CAD. The intention was to have it CNC bent, but I needed to use tight radius bends to keep clearances up and line up at the top of the flex joint. (I want to retain the same length flex joint as factory - 6") so they will have to be fabricated.
Would anyone else be interested in a set of pipes like this?
Obviously mostly directed at Australian residents, but wouldn't rule out looking at shipping options for internationals.
I've attached the driver's side (RHD) exhaust as recreated in CAD and 3D printed for trial fit from the set-out tools I made.
Just a real quicky overlay in photoshop to check clearances, but you get the idea.
Short section of 2" into an adaptor to a 2.5" bend to the flex joint.
I believe for those without DPF, you will not 'need' a tune as there will be no errors, but the DPF people will have to do something to make the warning lights go away.
