1 - 9 of 9 Posts
Hi I have just bought a 2005 Tourareg which is a beautiful car but am having a few issues with it in the respect of lack of power, I have changed the fuel filters but it still doesn't get up & go as it should, any help as what the problem could be would be greatly appreciated.
Cheers.
boost leak perhaps.
Get a VCDS scan.
Cheers.
Thanks for that i have had my snap on scan tool on it & it came up with a code P3336 but haven't had the time to look any further yet.
Multiple v10tdi owner
(3)2004 V10tdi’s
N18 valves also can cause that code.
you need a VCDS scan.
Discussion Starter #9
The problem is intermittent & some times it goes like a bullet, I am going to start doing a continuity check on the wiring which controls the turbo module, suspect may be a partial broken wire somewhere..
Regards Fordys..
1 - 9 of 9 Posts
