V10 tdi fuel rail install
3.3K views 6 replies 4 participants last post by  veeten
Nearing the home stretch with operation oil cleanup on my 07 v10 and need to know whether the fuel rail needs a little love tap on each leg of the rail with light hammering order to seat the rail on the o- rings or just tighten the screws to draw the rail to rest.
Any insight appreciated
Thanks for the reply, so your saying the rail will require the use of a hammer in order to get the rail fully seated?
I have lubed both the seal and opening of the rail
Rail is centered and on with a bare minimum of bolt tightness just to hold the rail to the seal
I was going to alternate between tapping and tightening
Not saying you have to use a hammer, but it does take a bit of force to get all the o-rings in at the same time. Your method of achieving the end result is up to you ;)
