Hello Fellow Treggers
I've got a V10 with an irritating issue. For days it will start "On the button" but then sometimes it will let me down and I have to put the key in click it back (to the left) then the car starts well using the consumer battery,
both battery's have been replaced, I have read several posts about people experiencing similar issues, but
no one has really nailed the issue, I've heard people say there are connections that need checking, I have done a visual in the boot (the battery/tyre well there had at some point been flooded with water!) but the solenoid is fine I checked it manually for operation and resistance and its reliable. The volt meter always shows just over 14v when engine is running backed up by my fluke dvm.
Also the carpet in the front foot wells has been damp (I have now cleared the drains in the bulkhead)
I have also noticed that if it fails first thing it will often fire up well on the button just a few minutes later, to me that says its not a failing battery (unless the clever electronics are still using the front/both batts?)
I am really stuck chaps, any advice or experiences would be very gratefully received.
I don't have VAG.com and live in Essex, also unfortunately I have been made redundant
so cant afford to buy and change modules without good reason.
Hoping someone has some good advice
Regards Mark
(2003 V10 130kMiles)
Regards Mark
