V10 oil leak pressure piston lh side
1.1K views 0 replies 1 participant last post by  Jvang
Touareg v10 oil leak update
Update on the oil leak from the pressure piston lh side! Took off the oil feed line on the engine block - underneat the fuelfilter assambly. The hardest part was to take off the pipe clamp next to the pressure piston. Gezz! I had to push the piping away from the cylinderhead - just a little. I hope it turns out okay and no new leaks on the turbo oil inlet
I found a tool for bile steering fitting and cut in down in length - works okay.
The o-ring was hard like stone and did not seal .
Now I have most back together but the fuelpump and the rest an top of the engine
