Been out for a drive today and returned home in limp mode. Whilst driving we had a lack of power,will barely rev above 2.5K,oil sensor workshop is now displaying. Also whether conicidence or not the red brake warning popped up briefly as well.
Returned and pulled a scan to reveal both turbo control modules with faults,both intake flap motors with faults and also the oil temp/level sender fault. The oil temp guage is registering zero.
All these components are on the same fuse,but this seems OK.
Here are the scan results.
Address 01: Engine Labels: Redir Fail!
Part No SW: 070 906 016 AA HW: 028 101 148 1
Component: V10 5,0L EDCG000AGMÂŞ7000
Coding: 0010575
Shop #: WSC 31414 790 00001
VCID: 4FAD4662DDE59D469F-5140
3 Faults Found:
19556 - Motor for Intake Manifold Flap (V157)
P3100 - 000 - Short to Plus
Freeze Frame:
RPM: 630 /min
Torque: 71.1 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00001111
Torque: 387.1 Nm
Torque: 0.0 Nm
19791 - Control Module 1 for Turbocharger(s)
P3335 - 000 - Missing Message(s)
Freeze Frame:
RPM: 945 /min
Torque: 118.5 Nm
Speed: 0.0 km/h
Load: 9.8 %
Bin. Bits: 00000000
Bin. Bits: 00000000
Absolute Pres.: 1009.8 mbar
Absolute Pres.: 969.0 mbar
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 000 -
Freeze Frame:
RPM: 1008 /min
Torque: 181.7 Nm
Speed: 0.0 km/h
Load: 14.5 %
Voltage: 13.22 V
Temperature: 24.3°C
Temperature: 96.3°C
Temperature: 18.9°C
Readiness: 0 0 X X X
Address 11: Engine II Labels: Redir Fail!
Component: V10 5,0L EDCG000AGSÂŞ7000
Coding: 0010575
2 Faults Found:
19784 - Motor for Intake Manifold Tuning Flap 2 (V275)
P3328 - 000 - Short to Plus
Freeze Frame:
RPM: 630 /min
Torque: 71.1 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.70 V
Bin. Bits: 00001111
Torque: 387.1 Nm
Torque: 0.0 Nm
19792 - Control Module 2 for Turbocharger(s)
P3336 - 000 - Missing Message(s)
Freeze Frame:
RPM: 945 /min
Torque: 118.5 Nm
Speed: 0.0 km/h
Load: 9.8 %
Bin. Bits: 00000000
Bin. Bits: 00000000
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 980 L
Component: KOMBIINSTRUMENT RB8 2935
Coding: 0005421
VCID: 4189705A1BB17B3619-5140
2 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
010 - Open or Short to Plus
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Any help would be greatly appreciated.
Coding: 0010575
3 Faults Found:
Freeze Frame:
RPM: 630 /min
Torque: 71.1 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.63 V
Bin. Bits: 00001111
Torque: 387.1 Nm
Torque: 0.0 Nm
Freeze Frame:
RPM: 945 /min
Torque: 118.5 Nm
Speed: 0.0 km/h
Load: 9.8 %
Bin. Bits: 00000000
Bin. Bits: 00000000
P1654 - 000 -
Freeze Frame:
RPM: 1008 /min
Torque: 181.7 Nm
Speed: 0.0 km/h
Load: 14.5 %
Voltage: 13.22 V
Temperature: 24.3°C
Temperature: 96.3°C
Temperature: 18.9°C
Coding: 0010575
2 Faults Found:
Freeze Frame:
RPM: 630 /min
Torque: 71.1 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.70 V
Bin. Bits: 00001111
Torque: 387.1 Nm
Torque: 0.0 Nm
Freeze Frame:
RPM: 945 /min
Torque: 118.5 Nm
Speed: 0.0 km/h
Load: 9.8 %
Bin. Bits: 00000000
Bin. Bits: 00000000
Coding: 0005421
2 Faults Found:
011 - Open Circuit
