The following represents research I've done on the two batteries required for the V10 TDI. Most place's websites didn't show batteries for the Touareg V10 TDI, and some showed incorrect information. So I visited the various parts stores in person armed with the battery specs and a note pad and found the batteries we need ... even if it involved digging through the battery racks myself.
If you discover any other data or corrections to this data, please feel free to respond - I'm not a battery expert. Also, the prices may change regionally or over time.
Compiled Jun 5, 2012.
General Battery specs:
For trunk well: (H8 Series Battery)
Dimensions: 13 3/4” X 7” X 7 1/2”
12V 900 CA , 720 CCA
Under Driver’s Seat: (Group 49 Battery)
Dimensions: 12 3/8 ” (12.4) X 6 7/8” (6.90) X 7 1/2” (7.48)
12V 1000 CA, 850 CCA
Top Terminal (Positive Terminal on Right)
Reference numbers: MTP-H7 H7(94R)
Interstate Batteries:
For trunk well:
Product ID:
MTP-49/H8 non-AGM $184.95
Product ID:
MTP-49/H8A AGM $293.95
Cranking Amps:
900
Cold Cranking Amps:
720
Voltage:
12
Weight:
52
Width:
6.89
Length:
13.94
Height:
7.48
Product ID:
MTP-95R/H9 $196.95
Voltage:
12
Weight:
63.9
Width:
6.94
Length:
15.56
Height:
7.5
AutoZone:
For Trunk Well:
H8-DLG Duralast Gold $134.99
900 CA / 760 CCA
49-DL $109.99
1000 CA / 850 CCA
13 15/16 x 6 7/8 x 7 1/2
OR
94R – DLG $164.99
990 CA / 790 CCA
O’Reilly:
For Trunk Well:
SuperStart 49 EXT(AGM) $169.99
OR
Superstart 49 EXT $124.99
OR
94R-EXT $164.99
CA 910 / 765 CCA
Volkswagen Dealerships:
Here's the part numbers - not sure which goes where:
Part # 000915105DLDSP $199.00
85aH, 480 Amp
AND
Part # 000915105CEDSP $225.00
110aH and 520 Amps
(both special order items)
Pep Boys:
For trunk well:
H6-770 PP $153.99
Cranking Amps: 900
Cold Cranking Amps: 770
(Not as wide as stock battery)
49-850 B $108.99
Cranking Amps: 1000
Cold Cranking Amps: 850
(Battery Terminals not reversed)
OR
94R-730B $ 158.99
Cranking Amps: 875
Cold Cranking Amps: 730
Wal-Mart:
For trunk well:
Everstart Max
Maxx-H8 #14 $107.96
990 CA / 760 CCA
Maxx-94R $109
900CA / 765 CCA
12.44 x 6.94 x 7.48
Batteries Plus:
For trunk well:
SLI 49-H8M $125.00
??? CA / 900 CCA
SLI 94R-H7 $149.99
??? CA / 765 CCA
NAPA:
For trunk well:
75-49 $129.00
1080 CA / 900 CCA
75-94R $169.00
910 CA / 765 CCA
Please add comments and corrections. I make no recommendations - just presented this list for the benefit of all.
For trunk well:
Product ID:
Product ID:
Cranking Amps:
900
Cold Cranking Amps:
720
Voltage:
12
Weight:
52
Width:
6.89
Length:
13.94
Height:
7.48
Product ID:
MTP-95R/H9 $196.95
Voltage:
12
Weight:
63.9
Width:
6.94
Length:
15.56
Height:
7.5
AutoZone:
For Trunk Well:
900 CA / 760 CCA
49-DL $109.99
1000 CA / 850 CCA
OR
94R – DLG $164.99
990 CA / 790 CCA
O’Reilly:
For Trunk Well:
OR
OR
94R-EXT $164.99
CA 910 / 765 CCA
85aH, 480 Amp
AND
110aH and 520 Amps
Pep Boys:
For trunk well:
H6-770 PP $153.99
Cranking Amps: 900
49-850 B $108.99
Cranking Amps: 1000
OR
94R-730B $ 158.99
Cranking Amps: 875
Wal-Mart:
For trunk well:
Everstart Max
Maxx-H8 #14 $107.96
990 CA / 760 CCA
Maxx-94R $109
900CA / 765 CCA
12.44 x 6.94 x 7.48
Batteries Plus:
For trunk well:
SLI 49-H8M $125.00
??? CA / 900 CCA
SLI 94R-H7 $149.99
??? CA / 765 CCA
NAPA:
For trunk well:
75-49 $129.00
1080 CA / 900 CCA
75-94R $169.00
910 CA / 765 CCA
