I am in the process of importing my Touareg 2014 from US into Sweden, where the car is already located.
The inspection requires modifying the tail lights to European standard which means that the directional tail lights should be amber. The VW dealer declared unable to perform this.
The Euro Touaregs use a different sector for this specific function, although externally the complete set looks the same. This means that modification to the cabling and control board might be needed.
Quite an interesting technical challenge if it were not for the time constraint. I have less than 1 month to fix it acc to the import process, therefore the urgency.
Any recommendation is very much appreciated.
