Indeed. And neither in my short distance driving uphill to the marina and back or cross-country going through the Catskills have I ever experienced fade. A 20-ft boat weighs between 2,200 lb and 3,000 lb on average. there should be next to nothing on this planet that could make a Touareg factory brake system overload and fade having only 3,000 lb on itWhat is being described in the "sudden stop" situation is not brake fade.
This banter is a lot of effort...Seems like a lot of effort for a little 20 footer. No offense.
One day a car stopped in the middle of the road at the last second. My 20 footer had run out of hydraulic fluid once (didn't realize a line went..). ABS still chirped all 4 of the Touareg tires in an emergency stop one day. In the middle of a hill. Going downhill. Going 50mph. Zero fade.
Pulling a 6k lb car through the Catskills @ 75mph.. zero fade what so ever.
Again, based on my experiences with this car using OEM pads/rotors that can only be purchased AT the dealership, I'm blown away that you have ANY sort of braking issue with a little 20 foot boat.
Your weights are off.. Dry weight on my boat is 3400lbs, the motor and outdrive alone are 1000lbs of that. Steel dual axle trailer you can reasonably average 100lbs per foot so 2100 lbs. Add 250lbs of fuel, sporting goods, family, cooler and food the GVWR is higher than you are eyeballing.Indeed. And neither in my short distance driving uphill to the marina and back or cross-country going through the Catskills have I ever experienced fade. A 20-ft boat weighs between 2,200 lb and 3,000 lb on average. there should be next to nothing on this planet that could make a Touareg factory brake system overload and fade having only 3,000 lb on it
I'll fill you in how I didn't notice braking issues with busted trailer brakes: the Touareg brakes are capable of stopping significantly more weight than a 20ft boat carries.This banter is a lot of effort...
Holy pissing contest dude, "little 20 footer" and the walking to school in snow uphill both ways vibe...
This is sorta comical, you cannot imagine how I could get brake fade. I cannot fathom how you would not notice the brakes on your boat trailer had ceased functioning. My best guess is my combined GVRW has a few extra pounds to your setup.
I am currently using Genuine VW parts bought from my dealers part counter.
I doubt your boat trailer weighs 2100 lbs. Most boat trailers are lightweight aluminum. My tandem axle eagle boat trailer weighs ~1200.Your weights are off.. Dry weight on my boat is 3400lbs, the motor and outdrive alone are 1000lbs of that. Steel dual axle trailer you can reasonably average 100lbs per foot so 2100 lbs. Add 250lbs of fuel, sporting goods, family, cooler and food the GVWR is higher than you are eyeballing.
I
You are an oblivious driver if you can't tell your trailer brakes are not working with a 3,000+lb load pushing behind you. I did not come on here saying the stock brakes will not stop my load, I came on here saying that I get pedal fade.I'll fill you in how I didn't notice braking issues with busted trailer brakes: the Touareg brakes are capable of stopping significantly more weight than a 20ft boat carries.
So are you going through a massive several mile long mountain pass or something? Reading the show what you tow thread, there are people towing 30 and 35-ft campers weighing 8,000 lb and not even those people complain about brake fade.
I'm just trying to help you out here. You clearly have massive issues if your overbuilt quad piston brembo brakes are having issues with a 3,000 lb load.you still haven't even mentioned what your typical driving conditions are IE going straight down the back side of a mountain etcYou are an oblivious driver if you can't tell your trailer brakes are not working with a 3,000+lb load pushing behind you. I did not come on here saying the stock brakes will not stop my load, I came on here saying that I get pedal fade.
You have questioned me on electric brakes and water not mixing, not understanding my comment of "electric over hydraulic" making it pretty clear you do not know that system exists. Yet you are a self proclaimed expert on towing.
You are now stating that my steel boat trailer is made of aluminum based off what information?
A 35 foot camper will have electric brakes and a brake controller. As I stated prior my car/tractor trailer with electric brakes I can dial the brake force to a degree that is seamless. Or I can boost it so hard you can smoke all four tires with a slight tap on the brake. Frankly a touareg is not the ideal tow veh for a 35 foot camper. Yeah the toaureg will be great in the parking lots with it's short wheel base backing in and out of camping spots, but it is not gonna feel nearly as stable as a long wheelbase truck on the interstate.
You keep doing you and running around with a boat trailer with no brakes. I am after a better margin of safety for myself and those that I share the road with.
Quit making assumptions. There are lots of types of boats, so weights can vary quite a bit.Indeed. And neither in my short distance driving uphill to the marina and back or cross-country going through the Catskills have I ever experienced fade. A 20-ft boat weighs between 2,200 lb and 3,000 lb on average. there should be next to nothing on this planet that could make a Touareg factory brake system overload and fade having only 3,000 lb on it
Wow, 6600 lbs? That might be the heaviest 21 footer I've ever heard of.. what kind of boat is that?Quit making assumptions. There are lots of types of boats, so weights can vary quite a bit.
I have a 21 foot boat. Boat and Trailer with a full tank of fuel weighs almost 6600lbs.
Sent from my SM-G965W using Tapatalk
Rotor glazing is very possible, but highly unlikely if using factory brakes and pads that are changed at equal intervals unless this guy drives down the road with his foot on the brake.Brake fade is when the heat temperature of the brake components exceeds the design limits, and braking capability drops off. A sudden stop does not cause brake fade. It seems more likely you have glazed rotors/pads, and don't have the bite you should. Could also go to a pad with more initial bite.
That's the thing, we just don't know, all I know is that what he is describing is not brake fade. I personally think the stock pads lack bite anyway.Rotor glazing is very possible, but highly unlikely if using factory brakes and pads that are changed at equal intervals unless this guy drives down the road with his foot on the brake.
Sent from my SM-G965W using TapatalkWow, 6600 lbs? That might be the heaviest 21 footer I've ever heard of.. what kind of boat is that?
Wow. Definitely the heaviest 21 footer I've ever heard of, Jesus. Definitely an outlier though my man.Mastercraft XT21
If he doesn't take you up on that offer, would you pass it to the next person (me)?I have a set of Pagid semi-metallic pads with less than 1K miles on them that fit the 2011-2016 Touareg, these pads have unbelievable initial bite and no fade hard stopping power and are yours for free if you pay shipping via USPS Flat Rate box. PM me if interested
At 105K I replaced the original pads/rotors and went with Brembo HC rotors and the Pagid pads, the braking is great but the dusting is terrible. But, that is the trade off of a high friction pad.
I switched back to the OEM pad and still good braking and virtually no dust and for needs more than adequate.
And you got your OE rotors and pads directly from the Volkswagen parts counter?If he doesn't take you up on that offer, would you pass it to the next person (me)?
I changed out for OE pads/rotors but either the initial bite is underwhelming or I glazed the pads during break in. Not sure how I did it because I followed the directions I found around here to a T but now my wife's brakes give off a bit of squeal when reversing. Not sure if I can take them off and scuff everything to get some bite back but they don't inspire confidence in heavy stopping and it's my wife driving the two littles in the rig so...
Yeah. The dealers I've dealt with in my region are worse than useless--they're incompetent to the point of being destructive so I'm never going back.And you got your OE rotors and pads directly from the Volkswagen parts counter?
