1 - 2 of 2 Posts
The little yellow thing in the circle? Looks like it is a smaller picture of the larger picture. BUT the center differential is not engaged in the larger picture (center circle would be solid if engaged).
Does this picture not go away if you shift into neutral and select "high auto diff" then press left know back in and wait for a few seconds before shifting out of neutral?
If this doesn't go away with the above: stepper motor?
1 - 2 of 2 Posts
