1 - 14 of 14 Posts
Mgnimus
2015, Touareg 3.6 FSI Silver Metallic.
Discussion starter · #1 · (Edited)
Noticed a very insignificant wet spot below the engine bay the other night. When i pulled open the hood, i noticed this peculiar leakage that doesn't make sense to me. Can anyone help identify what it could be.
I dont wanna be that guy but... That looks like a crack that goes into your coolant galleries inside your engine, clean it off if with some scotch brite or sand paper (if you can reach it). its hard to tell in the photos but it could just be a leak dripping from above or being flung off of the lower pulleys into that corner. If it is a crack, depending on how OCD you are and how hard the fix is it might just be worth it to leave it and keep an eye on your coolant. The only other fix would be to pull the engine and have it welded. Taste it and let us know LOL
It's coolant being flung up and all over the place by the water pump pulley.
You can see the vacuum nipple for the water pump shroud right below it, and you can see the coolant on the ground in his 2nd pic.
Noticed a very insignificant wet spot below the engine bay the other night. When i pulled open the hood, i noticed this peculiar leakage that doesn't make sense to me. Can anyone help identify what it could be. View attachment 268965
Hello guys, as Savagesoot said, its coolant leakage related issue, I have same engine on my touareg 2014, And i have done some works on the cooling system, from what the pictures showing, its either water pump calling for replacement or the silicon tube that is connected to the water pump is leaking.
If you need more help I am living in UAE too.
Discussion starter · #10 ·
Haha thanks for the response. Will sure taste and let everyone know.
Discussion starter · #11 ·
Thanks for the response. Sure lets connect. Please also let me know your preffered garage you visit here in UAE for general maintenance.
1 - 14 of 14 Posts
