just looked at wiring schematics there are no fuses in between the sensor and the ECM. Could this have caused an issue inside the ECM? (btw I forgot to mention in the original post
the car will go out of limp mode if you clear the code before you start it or while you are driving it so at some point it works but once the car turns back off it goes into limp mode again)
