Underbody Protection for 2012 Touareg
1.3K views 15 replies 7 participants last post by  Lars_NM
Good afternoon, all!!
I own a 2012 Touareg, the Execline 3.0 L V6 TDI, and I am looking for an underbody protection kit for my ride. I understand that I would have the 7P. I live in Alberta, Canada, and enjoy backcountry camping and other activities. I will not be doing a lot of hard off-roading, but I want to protect the vital components of my Touareg from errant rocks as I travel the Forestry Trunk Road in search of sweet fishing spots.
I have searched online and found Eurowise in the US and Park Auto here in Canada. Eurowise sells the protection kit at +/- 3800 US (that does not include GST and tariffs). With those added, I am looking at $6000-6500 Canadian. I reached out to Park Auto and was told that they order the necessary parts from Eurowise, so I would not save much cash. Park Auto stated they would absorb the tariffs, but I eat the rest. Park Auto suggested that it may be cheaper for me to contact a metal fab shop and have them design and build the parts.
That sounds like a great idea, but if pre-fab underbody protection kits are available for a lot less than 6K, I would go that route.
What would be less costly? Pre-fab kits or having a metal shop fab what I need?
Does anyone out there have thoughts or suggestions? I am open and receptive to feedback.
I posted this in General Maintenance and then found this forum, so I am also asking here (as General Maintenance is probably the wrong forum.
MJ
Might I suggest only getting the Eurowise front skid plate. I really don't think you will need all of the other offerings, especially if you are not planning on doing a lot of hard off-roading. I've gone through some seriously nasty stuff in my 7P and the damage has been close to nothing. My Eurowise front skid however has taken a beating and saved a ton of potential damage.
The only additional under body protection Id go with would be the transfer case cover.
As far as steel vs aluminum I’m for more protection so steel it is. But then again if you’re not doing any hard off-roading then maybe aluminum would be enough.
Aluminum is a lot lighter but it can get stuck on rock points, as they dig into the soft metal. I’d look into the uk darkside/skidplate.com steel plates which are thinner than the eurowise ones and much cheaper. I have them on my T2 and they’ve been plenty strong- no warping or dents despite hitting a lot of rocks, and winching it out of deep mud sliding on the plate.
I have similar goals to yours. I drive on some Texas dirt roads that look like they belong in Gaza or Fallujah and I am concerned about a wheel dropping into a deep hole and my vulnerable undercarriage parts scraping the road. Not exactly offroading but definitely potentially hazardous terrain. So I checked out Wallace Offroad in Australia:
That's a complete coverage package (stainless) for less than $700US. Shipping to US for another $500US or so. But I have been texting back and forth with Brad and he is now considering having the heavy parts made here in Texas and shipping the rest from Australia, so costs should go down significantly. From an email:
"Ive actually had some good feedback from a manufacturer in Texas. I'm
thinking I'll send the hardware from Aus, and have the heavy items
made and shipped in the states. Should save a bundle in shipping.
I'll keep you posted."
They are also looking into an "affordable" bull bar front end protection product. I am definitely going with their "bash guards" (in their vernacular) but I am going to wait up to a few months until their outsourcing decision is resolved.
I just heard back from Brad and it looks like they won't be producing anything in the US:
"HI Bruce, With all the back and forward the best way I've found is to still make it in Australia, then ship to USA."
The price he quoted me seemed to be different however, so I emailed him again to confirm the "complete package" advertised on his website was accurate. I will post when I hear back.
BTW he will drill an oil drain plug access hole in the engine section if desired so you don't have to drop the guard to change the oil.
I have been doing serious off roading in my 7L, I've done several of the "expert" trails in the Durango/Silverton area (check out my posts for pictures).
I have about 2" increased ground clearance from oversized tires, a slight lift. I also have the VW 2mm steel "rough road" pan under the engine. The high price of the Eurowise components has put me off.
My recommendations are put the largest diameter AT tires on the car that you can, with the smallest rims (17") that will fit your car and go with a 1" spacer lift from Eurowise and leave it at that.
Aditional thoughts:
  • Learn to drive! You need to practice off road so you know where all the tires are at and what you have clearance to go over. Make up some drills for yourself.
  • Buy a good 12V air compressor so you can air down/up on the trail. ViAir is a good brand.
  • The engine is protected by the sub frame and not vulnerable to impacts.
  • The transfer case is the most vulnerable of the drive train components, so if I was to buy one thing it would be protection for that.
  • On skid plates always go with steel.
  • Most important: get a full size spare.
I appreciate your response! I have a full size spare, but only the tire at this point. I am looking for a good quality inexpensive rim for it. I am also looking at options for mounting said spare. Eurovision has a swing out spare tire mount. Again, quite expensive, so I am looking around for something else.
Steel it is. I have found that Wallace is a fifth the price of Eurowise, even with shipping. I will keep up my search!
#12 · (Edited)
Currently have over 151,515 principally off-road miles. Our TDI is totally stock with only body protection & camping gear added. Our aluminum skid-plates have worked well. Run 255/55/18s from the hot Chihuahuan desert up to the frozen Arctic Ocean at Tuk with many BDRs and Moab in between. Six BFG KO2s three season & studded Nokian Hakkapeliitta's winter.
Note we put our body protection on in 2013 when everything had to be custom fabricated.
PS - being from Canada consider going to BCOR.
[/QUOTE
The only option for inexpensive rim is a used factory rim. buy one that matches your existing wheels. This was my first solution, it cost me less than $100. But I had to fabricate it. with parts off amazon.
