For some reason my '14 Touareg doesn't have the usual fire blanket under the hood. Does VW no longer put the blanket under the hood anymore?
Likely a bean counter looking to shave a few bucks. My '07 V8 did not come with it so I bought one from VW. Was around $55 I think. Then I had to get the clips. Maybe it was because I got the last year of the T1 and you have the last year before the refresh. I'm sure your parts dept. can order it.For some reason my '14 Touareg doesn't have the usual fire blanket under the hood. Does VW no longer put the blanket under the hood anymore?
In many cars the Underside of the hood is fitted with a material that as some mentioned hushes the engine sound, but it designed to fall from the hood and help smother an engine fire God forbid one happened. The plastic clips will generally melt allowing the blanket to fall onto the engine.What is this fire blanket you speak of?
My 2013 Lux did not come with a hood blanket/insulation/sound absorber. I called the dealer and they are not finding one for any Touareg, but said if I had a part number, they could look it up that way. So, do any of you have the part number for a T3 hood blanket?
