Mine pump has clamps (crocodile clips) which attach to the battery terminal posts under the bonnet, next to the engine.2004 R5 steel suspension.
The tyre pump is supposed to be right beside the spare isn't it?
Where do you usually plug the tyre pump in?
Yep, I've got those battery posts too.Mine pump has clamps (crocodile clips) which attach to the battery terminal posts under the bonnet, next to the engine.
I don't know if T4 is the same as T1.
I had a thermatic fan that melted my fuse box then melted an inline 30amp fuse holder.As you now know, never use the cigarette lighter type sockets to run the compressor as the both the draw and the length of time will cause problems!
I'll have a look.There should be a quick connect to the right (looking towards the back) of the tool drawer under the front passenger seat.
OP has steel suspension. What you described is for the air suspension systems which allow you to fill tires via the built in pump for the system.There should be a quick connect to the right (looking towards the back) of the tool drawer under the front passenger seat.
