Today during my TYC/Genera Cabin Filter install I noticed the instruction mentioned to install the filter so the arrow points towards the drivers side. I was under the impression (oem) the arrow should point to either side (but not the ends) so you can ensure the air flow in correct. Therefore my question is should the part number and arrow be visible from the bottom when installing or not? This will be the only way to make sure I got it right.
