1 - 4 of 4 Posts
It's been about two years since I picked up my 2010 T2 Lux Limited VR6 and I just wanted to give an update about my experiences.
The car was World Auto Certified Pre-Owned by Volkswagen which came in very handy as VW warranties the car like a new car for 2 years / 24,000 miles from the time of purchase. (There is a $50 deductible per warrantied item.)
As part of the CPO preparation process, VW replaced the following before they put it up for sale:
-Driveshaft & Bearing
-Brakes & Pads all around
-Power Lift Gate Button
-Xenon Headlight
I have done the following under the CPO warranty.
-Horn Replaced (known issue)
-Comfort Control Module (alarm would randomly trigger when locking car)
-Valve Cover Gasket Failed (most likely because CPO dealership overfilled the oil by a quart)
-Main Engine Fan Replaced (Fans stay on for about minute after shutdown during warm weather. New part didn't fix the issue. Thermostats check out fine. "Operating as intended")
-HVAC Blower Motor Replaced (known issue)
-Passenger Airbag Light Replaced
-Serpentine Belt & Tensioner Replaced (started to hear a bearing noise between 5000-6000 RPM)
All in all, I've been very happy with the vehicle. It never leaves the asphalt so the 20 inch Mountain wheels help with the handling. I hope to add the Cayenne sway bars at some point.
I don't tow, so the VR6 has worked out fine for me. I like it's smoothness and considering this engine has been around forever, I feel it's probably a good mill if I "drive it until the wheels fall off". I know most here would think it's under powered and prefer the V8 or 3.0 but I've never been left wanting more power. More gas mileage is another story. :)
Cheers!
I was very happy with my allegedly underpowered 3.2, but then, of course, I'm a damned good driver who knows how to get the best out of any car! You're obviously just as good!!
How does one drive a certain way to achieve optimal MPG? New owner of a 2015 Hybrid here.
1 - 4 of 4 Posts
