Greetings. I recently purchased a Touareg and I'm experiencing transmission jerking has anyone experienced similar problems what could it be I've done some research and found it could be the valve body any and all help would be appreciated.
Greetings. I recently purchased a Touareg and I'm experiencing transmission jerking has anyone experienced similar problems what could it be I've done some research and found it could be the valve body any and all help would be appreciated. 2004 model V6
Try & describe the fault better than "it jerks" What mileage? VCDS has a gearbox reset option & may have a fault code logged. A low speed momentary loss of drive could be a transfer case issue rather than the gearbox.Hey I’m experiencing this problem. My 2015 v6 gas jerks. It happens periodically only when decelerating. When decelerating down to 20-35km/h and then I press the gas to accelerate again it jerks trying to find what gear it should be in. Any ideas?
The Touareg has 110,500km on it (69,000miles) it’s hard to describe but when I press the gas it’s like the brakes are momentarily pressed untill it finds a gear then lunges forward when the it ingages in gear.Try & describe the fault better than "it jerks" What mileage? VCDS has a gearbox reset option & may have a fault code logged. A low speed momentary loss of drive could be a transfer case issue rather than the gearbox.
The transmission warning has not come back at all, I do have an appointment to get the diff fluids, transfer case, and transmission fluid/filter changed next week. I am going to get my mechanic to scan to see if there are any codes.If you are sure it is the gearbox then I would renew the ATF & scan with VCDS. Then if no improvement it would have to go to an auto transmission specialist.
Earlier models, 6 speed, suffered with valve body & solenoid issues and yours sounds similar.
You seem to have several threads with similar issues. Did the transmission warning come back? or the vibration from the rear? Did you manage to drain & replace the oil in the diffs?
What have you tried so far?
