Transmission fluid change 2014 TDI - OEM or Aftermarket?
6.3K views 7 replies 4 participants last post by  jeffnhiscars
Hi guys,
2014 tdi touareg with 110k miles. I am planning on dropping the transmission pan, changing the filter and replacing what oil is lost in the process.
I found two kits from ecs tuning. One is oem parts for $450 and the other is aftermarket for $175. Any reason to stay with oem?
Was also planning on doing the diffs while I'm under there. Any recommendations on oil/kits for those? Planning to buy all this at once and DIY this but want to hit the easy button on tried and true parts. Any other sources to consider?
#2 · (Edited)
Hi guys,
Use Ravenol oils. Ravenol T-WS Lifetime for the gearbox. Order it yourself. Everthing is available. What is OEM? VW dont make oil or the filters they do however rebox things & charge more.
The gearbox isnt made by VW. When i changed the ATF I noticed the original from the factory filter was made by ROKI co ltd. The new one I fitted was made by MEYLE.
VW OEM oil filters cost more than Mann but are made by Mann the box is VW branded but I tend to throw them away.
