1 - 4 of 4 Posts
Hello,
My first post, I have to ask for help...:(
I replaced the chain(new) in my transfer case and the transfer case motor (with a used one off EBay). Put everything back together, now my motor is working fine, I can hear it, no error codes on the VAG-COM, no nothing. However, it won't unlock the transfer case. The TC is stuck locked. The wheels are locking, skipping, etc when I take turns. What could have I done wrong when I put the TC together. I DID take all the gears out, synchronizers, etc, to look at them for any sign of damage, but pretty sure I put them back together properly...One more thing, I might've overfilled it a little, I didn't go by 850 ml, my friend said to fill it until it starts spilling out, and that's the level, and by that method I think it was about .9 ml...Please advise...Any help is appreciated. Thank you in advance guys for taking the time to respond...I'm kinda stuck. Don't wanna drop the TC again...
Discussion Starter #2
...tomorrow I will take the motor out, and try to disengage it manually. I guess if that works, it's most likely the motor. if not, i'll have to take the TC apart again...:(((
I did take the motor out and concluded there’s something messed up in the transfer case. Unfortunately I have to drop it and take it apart again Friday...Ugh
1 - 4 of 4 Posts
