121 - 140 of 143 Posts
2019 CR launch edition. Factory towbar
this is fro the VW website
Updated: 2022/06/20
File type: zip
Coverage: Argentina*, Australia, Botswana*, Brazil*, Brunei*, Indonesia*, Israel, Lesotho*, Malaysia, Mexico*, Mozambique*, Namibia*, New Zealand, Philippines*, Singapore, South Africa, Swaziland*, Thailand*, Turkey*
Yes, I agree. I tried loading the June data and whilst the car recognised the software, it wouldn't load it, leaving me with the 2022.1. I asked the dealer to load the latest maps and he said they were already loaded.
Yep confusing. I suspect the ".1" is just the release iteration (i.e. first release) in 2022, and nothing to do with the month.
Normally the number after the year is the month of release. 2022.1 being Jan 22.
Font Terrestrial plant Multimedia Screenshot Event
This is the current version Audi use with their MIB3 platform, September 2022 released for ROW (including Aus/NZ).
Getting over the air updates monthly does make for a happy owner :)
Ok... google spreadsheet here.
Anyone else - please add lines if you're so inclined! (treg T5/CR only pls)
Computer Output device Personal computer Gadget Flat panel display
I am hitting brick walls trying to load P0573 version..................
Reactions: Singh
· Learner
Discussion Starter · #128 ·
2019 Launch Edition
Mine also has RW 2022.1 and PO 523. Also module 5F has a fault code that won't clear. There are some solutions to reset this fault online that involve the use of an XOR calculator to make changes in adaptions, I don't have the stones to try that yet. Cars in for a service next week, I will let the dealer deal with it.
Could someone with a launch edition that the update worked on post their 5F module details so I can compare please?
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 760 035 067 B HW: 760 035 067
Component: MU-H-LN-RW 046 2838
Coding: 02350608FF00000043510001000808301F0200E601A00402DF
Shop #: WSC 31414 028 00001
ASAM Dataset: EV_MUHigGen2pALPI 001001
ROD: EV_MUHigGen2pALPI_VW53.rod
VCID: 1471B2C5FEF9ABBB53B-8040
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 762 919 618 HW: 762 919 618
Component: ABT_Prem_R H40 5211
Serial number: VWZ6ZGW1130142
Data carrier:
Subsystem 2 - Part No: V03 959 809 AD
Component: MIB2P_RW_Q121 0523
Compact disc data bank:
Subsystem 3 - Part No: V03 959 800 EG
Component: Gracenote2 4009
Volume Control 1:
Subsystem 4 - Part No SW: 762 927 341 HW: 762 927 341
Component: VW536LLB H06 0109
Serial number: 2019022800000187
Media socket:
Subsystem 5 - Part No SW: 5G0 035 953 D HW: 0
H08 0014
1 Fault Found:
1555 - Check Software Version Management
B201A 00 [009] - -
[Check software version management]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 25
Mileage: 22787 km
Date: 2022.10.18
Time: 15:55:36
Voltage terminal 30: 11.9 V
Status_Software_Version_Management-module_name: zFAS_Var_B_CL020
Wayne
2019 Launch Edition
That fault appeared for me when I upgraded the firmware (not the maps) from 2828 to 2838.
The XOR thing is straightforward and works... Once you've done it, clear the fault and it won't come back.
Thanks, good to know it works and yes the fault appeared after the dealer updated me to 2838.
I will give the dealer a shot before I have a go myself.
Wayne
· Premium Member
MY21 V8 R-Line Grey
Ah that's a bit remiss of them. I guess most owners would never know if they don't read the codes... The error doesn't seem to affect anything other than the owners with the knowledge it's there :)
· Learner
Discussion Starter · #134 ·
The dealer should normally clear it post the upgrade...some do and some don't it seems
· Learner
Discussion Starter · #136 ·
With the latest versions of sw including that of AAwireless android auto dongle now the split screen works well with the right settings
Gps navigation device Automotive navigation system Vehicle Map Display device
· Learner
Discussion Starter · #138 ·
How to do that ? 🙏
Not much, get yourself an AAwireless dongle, plug it into the USB port and connect your android phone to it
· Learner
Discussion Starter · #140 ·
