I'm looking at pulling a mini winnie with my Touareg. I'm getting mixed info. about using sway bars but it seems like mostly not necessary for smaller trailers. I'm also curious about the electric trailer brakes and if adding a module is necessary for my TDI. Here are the trailer specs and I'm well within the towing capacity of the vehicle.
Base Weight (lbs / kg)
2980 / 1351.7
Hitch Weight (lbs / kg)
320 / 145.2
Length (ft-in / m)
19' 2'' / 5.8
My main question is do I need to use a sway bar hitch for something this small and do I need to add the electric trailer brake module to tow this trailer? If I do need to install an electric trailer brake module, what is recommended for the VW?
Thanks for your help!
2980 / 1351.7
320 / 145.2
Length (ft-in / m)
19' 2'' / 5.8
