Wait.. What.. Can you please attach photos of how close it is to rub in 50% and 100% steering?265/70/17 on a OEM 17x7.5 et55. No lift in these photos. Only rub at full lock under suspension articulation. Under normal driving conditions, no rub at all.
Sent from my iPhone using Tapatalk![]()
2016 tdi Lux. No air suspension. Yes facelift.Wait.. What.. Can you please attach photos of how close it is to rub in 50% and 100% steering?
3 more questions:
1. Do you have face-lift model of 7p body?
2. Air-suspension?
3. TDI?
Please my comments a few posts above. Wheel offset plays a big role on the tire rubbing both the front plastic wheel arch and the carpeted rear portion of the wheel liner.I made a simple template from wood that represents the increase in radius and width. And took some measurements and I also had the template run across the tire surface with the wheels turned in different degrees.
The wooden template is 265mm wide and there are 235mm between the screws, and I cannot see how you fit 31.7 tires. But obviously you do.
Tires are not 90 degrees straight in the corners, but I get interference with my template when testing, it's not much but enough in the front of the wheel house towards the intercoolers. I am also uncomfortable close to the upper control arm.
Another question, can you measure how "long/wide" your front wheel house is? (end to end in driving direction). I think maybe it's bigger on the face-lift model?
Yes, of course. Lower offset makes your wheels come further from the spindle making it turning in a bigger radius than if the center point of the wheel is aligned with the center of the spindle. A lower offset will render in a bigger motion, increasing the chance of rubbing on full wheel lock. The same is true if you have to high offset as well, but then you are probably hitting the inside of the wheel house towards the engine before you rub against the other surfaces. Ideally you would want the center of the circumference of the tire to line up with the center of the spindle, then your rotation point of the tire will be truly ideal in terms of wear and the possibility to allow for maximum movement.Please my comments a few posts above. Wheel offset plays a big role on the tire rubbing both the front plastic wheel arch and the carpeted rear portion of the wheel liner.
So yes, I understand the geometrics, I didn't think that 265/70R17 was possible on my car until I saw that you had it. But I have simulated and measured it whit all the complex geometry of the tire sidewall. I just made it simple with 90 degrees on my template.
Anyway.
I'm waiting for a chance to test mount a tire in above mentioned dimensions. I want to see the clearance in detail and decide how to proceed.
I also trying with a new security access code for my air suspension controller and see if I can modify the ride height
Sure thing. Have a friend with latest VCDS. On next service, I will see what can be done.Really interested in the access piece for Ride Height. Please keep us posted.
Want to update folks here on my final build:I found the information shared in this post is extremely helpful -- thank you all for that!
I have a 14 TDI R-Line and the stock wheel size is 275/45/R20 [29.7'' diameter] and weighs 35LBS/Tire.
I need to replace the tires and have narrowed my choices down to 2 specs:
1. Falken Wildpeak A/T Trail 255/55R20 [31" diameter - 40LBS]
2. Cooper Discoverer AT3 XLT LT275/55R20 [31.9" diameter - 10 Ply & E loading - 55LBS] however 35% more expensive than option 1
My heart says AT3 XLT but my sanity raises these questions:
Kindly share your thoughts?
- Will the Discoverer AT3 LT tires fit my vehicle? (Somewhere in the thread it was mentioned that a TDI has 275/55/20 BFG KO2 LT tires without rubbing?)
- Will the extra weight (20LBS / Tire!) from AT3 cause handling issues / stress issues with the rotors / suspension system?
- Do the benefits from the LT tires (thicker wall, higher PSI...) outweigh the 35% price difference between?
I mentioned this in a previous post but the amount of weight gained when getting larger wheels may seem insignificant but when you consider it's unsprung weight the impact on performance is much, much more noticeable.I just got 265/60/18 fallen at3w on and it’s making the esp go off on any sort of turn coming down the mountain. Anyone else have this issue?
