1 - 15 of 15 Posts
Hey everyone,
Ive owned the treg for a few years but I am new to the sight. Recently I had the passenger side headlight go dead. and then the dash lit up with almost every light imaginable. I changed the headlight unit, ballast and all, but its still dead. The car works but occasionally will throw random lights but then go off. Does anyone have any idea what could have happened? below is the VCDS auto scan of the faults found:
Address 05: Acc/Start Auth.Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 RHW: 5WK 470 26
Component: 17 Kessy6610
Revision: 66105312Serial number: VWZ3Z0E7311328
Coding: 0131304
Shop #: WSC 31414 000 00000
VCID: 3467295B54DB8381BB3-5122
Component: ELVXXXX
4 Faults Found:
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
00668 - Supply Voltage Terminal 30
009 - Open or Short to Ground - Intermittent
00087 - Terminal 30 for Starting Relevant Consumers
Address 09: Cent. Elect.Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 M
Component:3001
Coding: 0105695
Shop #: WSC 05078 444 54092
VCID: 4683639332470111157-5140
12 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
010 - Open or Short to Plus - Intermittent
00978 - Lamp for Low Beam; Left (M29)
01495 - Bulb for High-Beams; Left (M30)
006 - Short to Plus - Intermittent
01498 - Bulb for Parking Lamps; Right (M3)
00979 - Lamp for Low Beam; Right (M31)
007 - Short to Ground - Intermittent
01499 - Bulb for High-Beams; Right (M32)
00924 - Relay for Headlamp Cleaning System (J39)
008 - Implausible Signal - Intermittent
00907 - Intervention load Management
000 --
01800 - Light Switch (E1)
01520 - Rain and Light Recognition Sensor (G397)
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
00457 - Control Module for Network (J519)
Address 17: InstrumentsLabels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 981
2 Faults Found:
01335 - Drivers Seat/Mirror Position Control Module (J543)
Address 19: CAN GatewayLabels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN0101
Coding: 0000006
VCID: 70EFE54B6043FFA19FB-5122
3 Faults Found:
00463 - Control Module for Digital Sound Package (J525)
Address 1C: Position SensingLabels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint2200
Shop #: WSC 00000 000 00000
VCID: 4581649F0F410A091CD-5122
1 Fault Found:
00926 - Terminal 30
Address 22: AWDLabels: None
Part No: 0AD 927 755 AJ
Component: TRANSFERCASE0100
VCID: 0305BA8741F5F439729-5122
2 Faults Found:
00532 - Supply Voltage B+
02042 - Control Circuit for Motor in Transfer Case
011 - Open Circuit - Intermittent
Address 29: Left LightLabels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l)0001
Coding: 0000003
VCID: 66C3831352872111F57-515C
1 Fault Found:
00492 - Body Pitch Angle from Level Control Module
Address 32: Differential LocksLabels: None
Part No: 0AC 927 771 C
Component: SG-Quersperre5020
VCID: 387F1D6B48B367E197B-5140
1 Fault Found:
Address 36: Seat Mem. DrvrLabels: None
Part No: 7L0 959 760
Component: Sitzverstellung0701
VCID: 77FDDE57052DA8995E1-5122
1 Fault Found:
Address 37: NavigationLabels: 7L6-919-887-DVD.lbl
Part No: 7L6 919 887 C
Component:Navigation0814
Coding: 0000101
2 Faults Found:
01064 - Terminal 58d; Interior Dimming
Address 39: Right LightLabels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r)0001
Coding: 0000017
VCID: 67DD8E17558D3819CE1-5104
2 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
01539 - Headlights Not Adjusted
Address 46: Central Conv.Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 E
Component: 2L HSG0201
Coding: 0000085
VCID: 3E730B736A9759D15D7-4AE4
Subsystem 1 - Part No: 7L0 959 701 H
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 H
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 D
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 D
Component: Tuersteuergeraet HR 0201
13 Faults Found:
00927 - Terminal 30 (Right)
01516 - Terminal 30; Left
00926 - Terminal 30
01134 - Alarm Horn (H12)
000 --
01331 - Door Control Module; Driver Side (J386)
00932 - Electric Window Motor; Drivers Side (V147)
00485 - Drivers Outside Door Handle Central Locking Button (E369)
01332 - Door Control Module; Passenger Side (J387)
00486 - Front Passengers Outside Door Handle Central Locking Button (E370)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
Address 56: RadioLabels: 7L6-035-186-CD.lbl
Part No: 7L6 035 186 A
Component:Radio0814
Coding: 0004062
VCID: 3169204FABC9B6A9D05-5122
3 Faults Found:
00857 - CD Changer Unit (R41)
003 - Mechanical Failure
Address 68: Wiper Electr.Labels: 7L0-955-119-V2.clb
Address 69: TrailerLabels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 GHW: 7L0 907 383 G
Component: ANHAENGERELEKTRONIK 8854
Coding: 0000002
1 Fault Found:
Freeze Frame:
Count: 0
Count: 0
Address 6E: Ctrl Head RoofLabels: 7L6-919-044.lbl
Part No: 7L6 919 044 K
Component: DACHDISPLAY0538
Revision: 00700538Serial number: 2009289.06
VCID: 3F8D76776D9D50D9561-5122
2 Faults Found:
01305 - Databus for Infotainment
00446 - Function Limitation due to Under-Voltage
The car was in the shop recently and they put a new battery in. The car worked fine for a few hours of driving and then started to act up again. Is it possible that the battery was bad that was put in or could it be an alternator issue?
Check voltage at aux posts under hood. Charged battery should read about 12.3v. If you can get it running, check voltage on cluster gauge. Should be right around 14v. If way high(less likely) or low and only reading battery voltage(which will drop), your alternator is not up to par. I think by 05, the faulty alternator cable issue was fixed, so I would guess alternator issue and not cable.
It might actually only be the voltage regulator, which can be replaced separately. The brushes wear down and eventually fail. The A student would have soldered in new brushes before they got to 5mm long, but much easier to just swap in a new regulator. Not that it's easy to pull the alternator in a V8...it's close to a nightmare.
2006 V8 Touareg AIR, nav, hid
yes, good info on driver kick panel harness
I expect to be due for that soon, from phantom leak that comes down a-pillar.
Final Update. It was indeed the splices in the wiring bundle. It's kind of shocking really. Here is this massive bundle of wires that I can only believe is basically the backbone of the car, and it's got 3 crappy splices in it. Splices that are held together with tape.
The three splices were:
4 heavy gauge black wires (maybe 8 or 10 gauge)
2 super skinny black wires (maybe 24 gauge)
2 super skinny brown wires w a red stripe (again about 24 gauge)
I cut all the wires about 6 inches back and respliced them. The black ones were a PITA because of the gauge. I almost used a crimp cap or twist cap on them. I ended up using a little solder.
Be mindful - you assume all risk should you do this to your vehicle (and not me). I had my battery disconnected so I didn't make my problems any worse. Plus, sometimes black is the powered wire, and there's a lot of amperage in a car battery.
I'm 99% confident that the issue was the brown wire. It literally fell apart in my hands. You can see in the picture the green in the tape - that's corrosion leaking out of the skinny black one. I hope that this can help someone else in the same position I was. I'm also glad that it was a relatively quick and easy fix - the diagnosis took the longest.
That is such a great writeup and with good pictures to boot. Thank You a hundred times.
Original Link with pictures: 12
Discussion Starter · #10 ·
I pulled the battery and charged it and tested it. the battery is brand new and tests good. I looked through the wiring harness under the drivers feet and found the splices but they are all intact and are making a connection. My ground from the battery is good and all fuses are good. The battery however will die if left connected if the car is just sitting. So I know I must have a short someone. Is there any common place to look for a short in the wiring harness. Also the car is blowing the fuse to the passenger side low beam HID. Thanks for any help in advance.
The insulation on the wiring inside the headlights gets brittle and falls off leaving exposed wires. It's a known problem and may be the cause of the blowing fuse. Check it out ASAP would be my advice.
Oh crap! This one is starting to be a real pain...
Can you clear all the codes then rescan and repost the scan. That might help.
You have a new headlight, so it should be good. Wiring harness short, a bad ground, controller problem ???
Hi
You say you have problems with the passenger side headlight and got a complete new unit and it still not works.
To me I looks like it have not been coded correct or at all.
Coding: 0000003
Coding: 0000017
Both sides need to be coded the same and according to Rosstech a Treg with air suspension need to be coded 03. Your right side is coded 17 and that is not right. Need to be 03 like the left side. After it have been correct coded you need to do basic setting.
Be sure the lamp house connector is nice and firm in to the cars connector by wiggling the lamp house. That connection can some times need to be wiggled to be good.
Heavy discharge of battery can maybe be found by switching of all consumers and connect a voltmeter between battery minus and ground. It must show very low voltage else you have a system there is pulling too much power. Take out all fuses one by one to locate the faulty system. Maybe you find something. Good luck.
1 - 15 of 15 Posts
