1 - 15 of 15 Posts
Sorry man :-( so now you have both the hard copy and the soft one
Sometimes when I shift from park to drive nothing happens and I have to shift down to neutral and back to drive. Anything I should worry about?
Shall add it to my Treg Manintenance CD.
Bit optmistic in that a mechanic out back of beyond would probaly not be in the business of overhauling an 09D transmission
Discussion Starter #10
Quick question: can I use brake cleaner to clean the transmission pan and maybe spray the valve body without removing if I see some sludge?
I understand brake cleaner is not hard on plastic and seals. But will it evaporate completely without leaving residue which might mix with the new oil and ruin the oil change project.
1 - 15 of 15 Posts
