Hello, guys
Got the following error when scanning with VCDS:
After reading here, I've understood that the AFS module is kaput and decided to change it.
Did some research and I've found that the Passat bi-xenon AFS module is matching with this one and found one from a guy who was dismantling his car.
I've put the new module on and VCDS was saying this:
I think the modules are not so compatible after all. The one from the Touareg had 7L6 941 330 (R) and H6 SX 18 while the Passat's module had 7L6 941 330 (R) and H6 SX 17.
Is there a way to make them work? I've tried to get the long coding from the broken module and overwrite it with the new one but I couldn't find this option on the 55 Headlight Range from the VCDS.
Code:
02234 - Right Headlight Power Output Stage (J668)
002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 194
Time Indication: 0
Code:
Address 55: Headlight Range Labels: 7L6-907-357.lbl
Control Module Part Number: 7L6 907 357 HW: 7L6 907 357
Component and/or Version: AFS-Steuergeraet 0003
Software Coding: 0000003
Work Shop Code: WSC 31414 000 00000
Additional Info: 7L6941329 AFS-Lst.-Modul l X018 7L6941330 AFS-Lst.-Modul r X017
VCID: 78F5B52208D3438FAE-5178
3 Faults Found:
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 213
Time Indication: 0
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 213
Time Indication: 0
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 213
Time Indication: 0
