My 2010 Touareg 7L has developed an issue with the power rear lid, hoping someone here would know where to look to try and fix it.
The Issue
The rear lid (The entire thing not just the glass part) opens fine electronically using the driver door button and remote etc.
Once open, it will not close using the close button (F206) located at the bottom of the boot lid.
The close button used to work fine, it just stopped working one day.
I have to push the boot lid closed manually and it locks fine.
Troubleshooting I've done
All the above leads me to think it is some sort of software setting issue. But what?
I have a tow bar fitted although I doubt it has anything to do with it. It used to work fine with the two bar until few months ago.
Below is a screenshot of the 6D Electric Trunk settings in VCDS.
Any suggestions ?
Has anyone got a 7L Touareg? What is your setting like?
VCDS shows activated when button is pressed
VCDS Settings for 6D trunk module.
Thanks.
The Issue
- I have checked the wires(continuity test) and all 4 wires are fine from the button all the way to the lid control module hidden at the bottom left corner of the car.
- Thinking it was the button itself, I replaced it with another one.
- Using VCDS I can see the button activating when pressed.
- Done the VCDS test for the 6D trunk elect. and the boot lid activates in both directions electronically (Open and Close) without any issue.
- Done Basic settings as per instructions here. Didn't solve the problem.
Any suggestions ?
Thanks.
