I'm trying to tap an additional pair of DRL/Signal lights to the headlight of a 2013 Touareg, and set them somewhere close to front grille. Let alone the challenge of accessing the headlight, I wonder if anyone has any information/reference about the wiring color code of headlight? I need to figure out which color/wire to tap into, for DRL and turn signal, respectively.
Any help would be appreciated...:grin2:
2015 TDI Exec R-Line
I’ll post a wiring diagram later. With or without Xenon?
Standard German wiring would dictate the left parking light would be gray/black and right gray/red. Left signal would be black/white, and right black/green.
Discussion Starter · #4 ·
With Xenon for me
Thank you sir!
looking for a wiring diagram for lhs high beam to tap into for a led light bar install..14 pin plug .. think it's black and white wire #11... car is 2013 touareg rline 7p with rh side drive....appreciate any help ..ta
