Hey all, I just successfully repaired (not replaced) an original 0AD341601A transfer case motor.
The car is a 2004 Touareg V6 with 297000km on the clock, flashing with the diff lock switch and complaining about "System Fault Workshop".
VCDS revealed a 02039 g398 010 potentiometer open or short to +plus.
After reading up on the various problems folks have had with poor battery (typically code 008, not 010), broken cable wires (a variety of errors) and replacing the motor I first checked all the wires in the cable loom and they were found to be all good.
I dismounted the motor and found that it had some road salt ingress. I removed the locking washer for the potentiometer, disconnected the cables and turned the potentiometer by hand. It rattled. I washed it with isopropanol, IPA. Quiet.
There seem to be two potentiometers and one NTC resistor in the black potentiometer case. The three outer pins are potentiometers on each side and the middle two pins seem to be the NTC resistor connection. The potentiometer readings should be between 1.2k-2.2k when turning the wheel.
Mine had discontinuity for part of the revolution, not sure if this is the expected behaviour or not but anyway IT WORKS after putting it all together again. Error codes are gone, no more "System Fault Workshop" warning.
So before firing the parts cannon for a couple of hundred $$$, try cleaning your potentiometer with some IPA electronics cleaner first - especially if you have 02039 010 and not 02039 008.
Good luck!
Good luck!
