1 - 4 of 4 Posts
:confused::)Hello
I am buying Touareg 2.5 diesel tdi, 2005. On what kind of issues should I be carefoul on when buying this car?
Thank you for your help
Only use 505.01/506.01 oil.
DO NOT use 507.00 oil
As above.
Read the buying a used Touareg thread. Link is in my signature below.
To add to that, only use a 5w40 505.01 oil :)
Other oils cause camshaft wear. The coupling between the gear train, power steering, and AC compressor can wear out. On the 5 cylinder I don't think it's that bad of a job to change though.
-J
1 - 4 of 4 Posts
