New upper and lower control arms new tire rod ends new swaybar bushings and links
Performing alignment: rear end aligned perfectly. I moved to the front and I can get the camber and caster perfect but is soon as I change toe the camber goes out and so I re-adjust camber and toe goes out and I go back-and-forth between the two and can’t get both perfect?
Any thoughts?
I’m baffled how toe can affect camber if the eccentric’s are all tight in the bushings are all new.
Use a machine that is calibrated to the touareg. Work in the order specified by the notes on the machine.
A related note - not so relevant to the OP’s question but for those with air suspension, please set the suspension height to normal before aligning ;-)
I’m using my Hunter Hawkeye alignment rack -so all of the above suggestions are covered.
Ride height setting/measuring is one of the steps to the alignment.
