Sunday,14,November,2021,09:24:30:14865
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WVGZE77L87D016513 License Plate:
Mileage: 207910km-129189mi Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZE77L87D016513 Mileage: 207910km-129189miles
Address 01: Engine Labels: 03H-906-032-BLV.clb
Part No SW: 03H 997 033 R HW: 03H 906 032 E
Component: T 3.6-FSI-LEV2 G00 2374
Revision: --H05--- Serial number: VWZ3Z0F2511497
Coding: 0001175
Shop #: WSC 08112 444 104936
VCID: 3C213C6C1A7806FBBB9-5184
VINID: 9E65EA5471DC2075000461410C01EA986C
2 Faults Found:
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 207790 km
Time Indication: 0
Freeze Frame:
RPM: 683 /min
Load: 25.5 %
Speed: 0.0 km/h
Temperature: 84.0°C
Temperature: 38.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.843 V
008577 - Performance Malfunction in Cooling System
P2181 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 207885 km
Time Indication: 0
Freeze Frame:
RPM: 1861 /min
Load: 66.6 %
Speed: 46.0 km/h
Temperature: 57.0°C
Temperature: 10.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 FF HW: 09D 927 750 FF
Component: AL 750 6A 1274
Revision: 00H51000 Serial number:
Coding: 0004216
Shop #: WSC 08160 444 85848
VCID: 77ABE34063DEE5A396B-5160
2 Faults Found:
01045 - Tiptronic Switch (F189)
008 - Implausible Signal - Intermittent
00789 - Backup Switch (F41)
009 - Open or Short to Ground - Intermittent
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0014338
Shop #: WSC 31414 790 00001
VCID: 3D27316801620FF38C7-5184
2 Faults Found:
00778 - Steering Angle Sensor (G85)
000 - -
01673 - Potentiometer for Diaphragm Position in Brake Booster
012 - Electrical Fault in Circuit
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 137 C HW: 7L0 909 137 C
Component: 1M Kessy 6850
Revision: 00H23072 Serial number: VWZ3Z0F2511497
Coding: 0000232
VCID: 333317503726C9836A3-5184
Component: ELV XXXX
1 Fault Found:
00165 - Switch for Transmission Position P/N
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 0
Reset counter: 116
Time Indication: 0
Date: 2000.00.00
Time: 02:09:08
Part No: 7L6 907 040 T
Component: CLIMAtronic R/L 4222
Coding: 0020030
VCID: 41DF4D987D9A6B13E8F-5184
1 Fault Found:
01592 - Air Quality Sensor (G238)
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 M
Component: 3003
Coding: 0100447
VCID: 46D55E8454B44C2BDDD-5184
11 Faults Found:
00967 - Left Turn Signals
014 - Defective - Intermittent
01494 - Bulb for Parking Lamps; Left (M1)
00978 - Lamp for Low Beam; Left (M29)
01495 - Bulb for High-Beams; Left (M30)
01498 - Bulb for Parking Lamps; Right (M3)
00979 - Lamp for Low Beam; Right (M31)
01499 - Bulb for High-Beams; Right (M32)
00060 - Foglight Lamps
00907 - Intervention load Management
000 - - - Intermittent
01520 - Rain and Light Recognition Sensor (G397)
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 05 Airbag 8.4E++H01 0562
Revision: BB38727 Serial number: 0009044?
Coding: 0012341
VCID: 2809F03CFEE0BA5BCF1-5184
Subsystem 1 - Part No: 7L0 959 339 C
Component: BF-Gewichtsens. 006 0008
No fault code found.
Part No: 7L6 953 549 H
Component: Lenksäulenmodul 3401
Coding: 0010031
VCID: 44D1448C62887E3BC39-5184
1 Fault Found:
01336 - Company Data Bus for Comfort System
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 971 G
Component: KOMBIINSTRUMENT RB8 2111
Coding: 0007231
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B9D85C06B0B29B571-5184
1 Fault Found:
011 - Open Circuit
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
Shop #: WSC 00000 000 00000
VCID: 45D7598869B24733D47-5184
Address 22: AWD Labels: None
Part No: 0AD 927 755 AT
Component: TRANSFERCASE 0114
VCID: 0D47A1A87142FF73DC7-5184
1 Fault Found:
02025 - Supply Voltage for External Components
Address 36: Seat Mem. Drvr Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0702
VCID: 77ABE34063DEE5A396B-5184
Part No: 7L0 959 933 E
Component: 2M HSG 0201
Coding: 0000085
Shop #: WSC 02352 444 84032
VCID: 3E2536640C6414EB95D-4B1E
Subsystem 1 - Part No: 7L0 959 701 G
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 G
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 C
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 C
Component: Tuersteuergeraet HR 0201
8 Faults Found:
00927 - Terminal 30 (Right)
011 - Open Circuit - Intermittent
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
00987 - Lamp for Brake Light; Left (M9)
01503 - Bulb for 3rd Brake Light (M25)
011 - Open Circuit
00914 - Window Regulator Switch; Rear Left; Driver (E53)
007 - Short to Ground - Intermittent
00936 - Electric Window Switch in Front Passenger Door (E107).
00930 - Locking Module for Central Locking; Rear Left (F222)
Address 56: Radio Labels: 7L6-035-180-56.lbl
Part No: 7L6 035 180 H
Component: Radio DE2 0003
Coding: 0001405
VCID: 323D1254C83CC08B615-5184
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L0 955 119 K
Component: Front Wiper 4027
Coding: 0000341
Shop #: WSC 31414 790 376833
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 180706 014 1201
Coding: 00208933
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 G HW: 7L0 907 383 G
Component: ANHAENGERELEKTRONIK 8854
Coding: 0000002
VCID: 3829207C2E402ADB5F1-5184
1 Fault Found:
16347 - Control Module - EEPROM Error
014 - Defective
Freeze Frame:
Count: 0
Count: 0
Address 6D: Trunk Elect. Labels: 7L6-959-107.clb
Part No SW: 7L6 959 107 HW: 7L6 959 107
Component: J605 HECKKLAPPE 1110
Revision: --H05--- Serial number: --------004843
Coding: 0022110
VCID: 78A9E07C6EC0EADB9F1-5184
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 224
Time Indication: 0
Address 6E: Ctrl Head Roof Labels: None
Part No: 7L6 919 044 T
Component: DACHDISPLAY 0539
Revision: 00900539 Serial number: 2009289.07
VCID: 48C950BC5EA05A5B2F1-5184
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
VCID: 392F2578154A33D3A0F-5184
3 Faults Found:
00434 - Left Front Inner Parking Aid Sensor (G332)
00435 - Front Right Inner Parking Aid Sensor (G333)
01548 - Sensor for Parking Aid; Rear Right (G206)
006 - Short to Plus
End----------(Elapsed Time: 08:13, VBatt start/end: 11.8V/14.0V)-----------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 05: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 1C: DTCs cleared
Address 22: DTCs cleared
Address 36: DTCs cleared
Address 46: DTCs cleared
Address 56: DTCs cleared
Address 68: DTCs cleared
Address 69: DTCs cleared
Address 6D: DTCs cleared
Address 6E: DTCs cleared
