150TDI MY15
Background
I currently have a 2008 V6 TDI 4XMotion Touareg and am looking to replace it. Current uses are around town, highway touring, some towing and off road work but nothing too serious - I rarely use the low ratio or the diff locks however it was good to know they were there. Have a spare 17" wheel which I cart around for a bit of off road security.
What to Update to
Based on my own experiences and those of others on this forum I wouldn't hesitate to get another 4XMotions however there are very few 2013/2014 models available - looks like I may have to settle for a 4Motion 2013 or 2014 model with air suspension.
Off Road
How capable are the 4Motions off road - I have read many forum posts but am still none the wiser?
150 Vs 180 - I don't really need the extra power but the air lift suspension would be handy for better ground clearance. Apart from that and the 18" v 20" wheels and a few nice things inside there is not much difference - apart from approx. $12,000. I assume they are both just as capable off road as both use the Torsen system - any comments?
"Lock" Button
The 180 has a "lock" button next to the off road dial (the 150 does not) - does this lock the centre diff. If so does this mean drive can be through the front and rear axles at the same time which makes the 180 a better option?
Its not a Jeep
I have driven the GC and the latest Prado and would still prefer the Touareg but would like to better understand what it can do off road - thanks for your comments
2011 (MY12) V6 TDI180 4XMotion, 275,000km
'Lock' button locks height level of air suspension. Without locking, air suspension level has speed constraints. E.g if you select 'off-road' height, the air suspension will automatically revert to 'on-road' height at 70 kph, and won't resume 'off-road' height until below 40 kph. If you 'lock' the air suspension having selected 'off-road' height, the electronic wizardry will limit your max speed to 70kph, no matter how hard you depress the accelerator pedal.
When stationary, holding down the 'Lock' button for about 7 secs will select 'Jacking Mode'. It's all in the manual.
Would be worth reading this recent thread on views on off-road capabilities.... http://www.clubtouareg.com/forums/f...d-rocky-tracks-in-2012-or-later-218290-2.html
I own a 2014 4XMotion and have had it now for 9 months. To answer a few of your questions, in my opinion:
1. Air Suspension - excellent feature and I use it regularly off-road to gain better ground clearance. Plus the auto levelling with towing is another benefit.
2. 150/180 - I have the 180, haven't driven the 150. The 180 has all the power I have ever needed, and I am sure the 150 would be the similar.
3. Off-road Capability - read above thread. I owned a 2012 Prado, and I am more than convinced my Touareg will go anywhere the Prado went and more. With the low-range and diff locks, the Touareg will go further than most people would ever be game to climb/descend/travel over.
I was in a similar position to you, I sold a V8 Grand Cherokee and purchased a 2013 4Motion Touareg.
The lack of a low range transfer case and locking diffs concerned me a lot, but to be honest with all the electronics on board I don't think you really need them anymore. First gear in the 8 speed is damn low and the grunt from the 180Kw diesel really negates the need for low range in my view.
The air suspension is terrific, I also tow a caravan and the self leveling is superb.
After a few trips and some off road travel I have grown to feel confident that these rigs are damn capable. It does feel a little weird not having a low range but i think that stems from the old guys and their definition of soft roaders.
The biggest issue is always going to be road tires.....
150TDI MY15
Thanks for the responses.
I will continue too look for a late model 4xMotion however if nothing turns up in the next month I will go for the 4Motion and try to pick up some 18" wheels
