Thinking of buying 2015 Volkswagen Touareg V6 TDI 7P Auto 4MOTION MY15
1.4K views 12 replies 7 participants last post by  volkswagens-for-life
Hi I am thinking of getting a 2015 Volkswagen Touareg V6 TDI 7P Auto 4MOTION MY15
I will be doing some reasonable to light 4wd and towing a camper trailer with boat onto into some remote ish places I’m new to all this so is this car something that’ll suit ?
Keep in mind that with a TDI you're also going to need to use it on highways for at least an hour or a bit more so the system can do a regen of the DPF. They also don't like to have the AdBlue just sit in the tank without being used as it can crystalize causing problems.
  • Helpful
Reactions: Mike in Anchorage
Greetings. The T3 can tow up to 7,000 lbs, so yes, IMO the T3 TDI would work fine for what you're looking for. If there are maintenance records available, I would check transmission fluid drain/fill intervals. I believe it's a 40k mile service. Good luck!
Yes the ACC can go "Pear Shaped" as you called it along with the camera module in the rear view mirror.
One reason I'm glad my '11 doesn't have those.
The newer year you go the more nanny controls there are to fail.
Reactions: KDSAjp
I know for the gassers VW says to use Top Tier fuel. Is it the same for diesel, is it even such a thing?
