So after that, we welcomed V2 to the family.
Super tidy car with some basic modifications. Had already had different shocks and a longer spring front and rear installed, front bash plate and a anderson plug routed into the boot. Picked it up at a decent price with the idea of esentially transferring bits and pieces over and building what I would think is a pretty capable offroad touring vehicle.
I decided to do things abit different this time around and try a more aggressive tyre on the same wheels I already had. Opted for the same size 275/65/18 but this time in a Kenda Klever R/T's. As you can see in the photos, far more aggressive then the old Hankooks. Decided to give these a go as I spend alot more time offroad then I used so wanted to try something with more sidewall bite and a softer compound. So far I rate them really well. A little noisy on road but nothing to complain about considering how aggressive they are. Plenty of grip in mud and on rocks also.
I opted to keep the longer springs and shocks in the front and rear but also add a 30mm lower strut extension in the front and a 20mm subframe drop. It gave me the slight front up look I prefer. I've tried to keep this one a little lower then the last one to keep the COG down. Mounted the roof tray setup on this car but decided to use the ROLA crossbars that were already fitted as I was never a big fan of having the silver rails on the old car. Pretty much had it all put together in a couple of hours.
