So abit more tinkering.
Decided to make up a upper strut spacer to get abit more lift out of the front end as it was nose down. This is what we have ended up with (note, the bolts are being replaced with a higher tensile bolt, this was just a mock up). Ended up with a 30mm upper spacer which gave us a pretty decent lift over what it already had.
Fit them up then ran into issues with the front CV's. I didn't expect to be hitting the limit of them already but I figure it was going to be getting close. It was fine on flat ground however once you start to accelerate and the front would droop is when it would cause issues. I had some 20mm subframe spacers cut up and put everything back in check geometry wise.
Flat Ground -
Full Droop -
Subframe spacer (need to be painted still)
This sorted alot of the issues we had. Drove fine, took it in and got a wheel alignment and they were still able to get everything back within factory specs which I was surprised about. Next point of call will probably be making some adjustable UCA's but this is pretty much how it sits.
Flat Ground -
Full Droop -
