1 - 3 of 3 Posts
You do need to remove them to measure them. The figure quoted is usually OD (outside diameter).Just use a set of vernier calipers.
These are the exhaust tips mounted on AU spec '08 Tdi, as you can see they straight not downswept.
However I would expect that the suitcase muffler would be the same so the tail coming out of the muffler should be the same, but make your own enquiries just to be sure.
TonyB
1 - 3 of 3 Posts
